ᐅ How can I customize and modify Ikea Besta units myself to fit sloped ceilings?
Created on: 5 Nov 2024 13:07
Kloga
Kloga
5 Nov 2024 13:07
I am planning to modify an Ikea Besta cabinet myself to fit perfectly into an attic apartment with sloped walls. Specifically, I want to adapt the floor-to-ceiling storage system to fit a sloping ceiling—meaning I need to accurately measure the dimensions and then cut or alter the furniture accordingly without compromising its stability.
What experiences do you have with modifications, especially regarding Ikea Besta, when dealing with sloped ceiling heights or non-standard wall angles?
I would especially appreciate tips on the necessary tools, the required work steps, and any advice on avoiding mistakes, since I’m doing this without professional carpenter assistance.
Thanks in advance!
klo61
5 Nov 2024 14:38
Hello Kloga,
First of all, I think it’s great that you are independently taking on a custom modification of the Ikea Besta. Especially with sloped ceilings, it’s always a visual and functional challenge.
Regarding your questions:
- Measuring accurately: I recommend first measuring the slope and ceiling height at several points using a spirit level and a protractor. Especially in older houses, the angles don’t always perfectly match the standard, so it’s best to double-check multiple times.
- Adjusting the front panels: The front panels of Besta can be fairly easily shortened or cut using a circular saw (ideally with a guide rail) or a router. It is important to finish the cut edges with appropriate edge banding to prevent fraying or loss of stability later on.
- Interior and carcass: Caution is needed here, as Besta mainly consists of panel material and connectors. When shortening or beveling the carcass, keep structural stability in mind. It can be helpful to use a reinforcing back panel, which you cut at the same angle.
- Tools: Circular saw with fine blade, tape measure, protractor, edge sander or sandpaper, and wood glue. If you don’t have a large circular saw, a jigsaw with a very fine blade will also work.
My tip: Always make a template from thin wood or cardboard first to test the slope on the furniture before working on the valuable Besta panels.
I hope this helps you so far. Just get in touch if you have any more questions!
Filippo
6 Nov 2024 09:22
klo61 schrieb:
I recommend first measuring the slope and ceiling height accurately at several points using a spirit level and an angle finder.
Exactly, this precision is the most important step. I would like to add a bit more detail, as converting a Besta wardrobe for sloped ceilings involves more than just measuring and cutting:
- First, you should create a digital 3D sketch of your sloped ceiling. Tools like SketchUp (available for free) are very helpful for better visualizing the available space and planning the best furniture placement.
- For the Besta modular system, it is crucial to cut the side panels at the back to exact dimensions. I recommend using small wooden blocks or strips as spacers and stabilizers in the corners because the slope increases stress on the joints otherwise.
- The front panels generally need to be cut at an angle (for slopes on upper floors, this is often around 10–30 degrees). Make sure not to damage the grain of the front panels when cutting—a sharp saw blade is essential.
- During assembly, I advise reinforcing the structure with metal brackets installed on the inside to improve overall stability, especially if you plan to remove or reposition shelves.
- A small tip: if you use the storage space down to floor level, be sure to check whether the floorboards are level. You can compensate for unevenness with small shims to prevent the wardrobe from being misaligned.
One more question: will you be trimming the existing Besta components, or are you planning to build the piece completely from scratch to measure? This affects the tools you will need and how precise the modifications can be.
klo61
7 Nov 2024 11:49
Filippo schrieb:
Are you planning to cut the existing Besta components to size, or are you thinking of assembling the entire piece of furniture completely new and to measure?
An important question, Filippo, which is often underestimated.
I would recommend: If possible, design the furniture to measure and consider the standard Besta components more like a modular system. This way, you can ensure that the parts fit really well. That means you might even purchase matching fronts and side panels separately and cut them yourself.
Cutting the original finished carcass panels without proper experience can lead to structural issues since these boards are usually reinforced only in specific places.
What can also work well:
- Modular adjustment by adding intermediate pieces or angled cuts in less visible areas,
- or building a custom frame in which the Besta modules are then placed or fitted.
Possibly even a combination of both.
I wish you good luck with your project and would be glad if you could share how it went after completion.
