ᐅ How can I modify IKEA BESTA to create a built-in solution for a beverage cooler?
Created on: 2 Feb 2023 08:17
Pra_mu
Hello everyone, I am planning to modify my IKEA Besta cabinet to integrate a beverage refrigerator as a built-in solution. Specifically, I want to understand how to alter the cabinet structure to install the refrigerator securely and neatly without losing the functionality of the other Besta components. I am also interested in how to properly plan the ventilation, as some beverage refrigerators require a certain amount of air circulation. Could someone provide advice on suitable dimensions and cutouts, and whether it is recommended to add insulation material to the furniture? Thanks in advance for your tips!
Pra_mu
2 Feb 2023 14:20
GALEO4 schrieb:
BESTA is simply not designed for technical equipment.
I understand that, but for cost reasons and due to the existing structure, I would like to work with the BESTA system as much as possible. Therefore, I am looking for practical modification and reinforcement options.
Another question: When connecting the electrical supply, do I need to consider any special routing or positioning to meet fire safety requirements? The refrigerator will not be easily accessible after installation.
Lorukeo
2 Feb 2023 15:08
From a safety perspective, I recommend planning the refrigerator’s power supply with an easily accessible electrical outlet. It is important to ensure that cables are not pinched or bent and that there is air circulation around the cable. Also, make sure that no heat sources such as lamps or electronic devices directly warm the refrigerator to avoid excessive energy consumption.
For fire safety, using a residual current device (RCD) is advisable, even though problems are rare. If your furniture allows, a recess behind the outlet can help route the cable neatly.
labar43
3 Feb 2023 08:33
Very exciting project, good luck with it! 😊 If I were you, I would definitely work with precision and especially ensure the refrigerator is very well ventilated – otherwise, it will consume a lot of energy!
Maybe you can also experiment with small casters or glide feet under the refrigerator. This way, you can easily pull it out when maintenance is needed! It makes everything much more flexible and less frustrating!
Keep at it, it’s going to be great!
KAUDRA62
3 Feb 2023 09:17
I agree with labar43 on this! 😉 There’s nothing more frustrating than a built-in refrigerator that’s difficult to remove if it breaks down.
I would rather suggest leaving a small gap so you can always access it easily. Besides that, proper airflow not only functions well technically but also gives a neat and tidy appearance.
With BESTA, you can also use decorative ventilation grilles that blend well with the furniture design. This way, the cabinet looks professional while you keep control over the technical aspects.
