ᐅ How can I use IKEA BESTA units as a built-in solution for a beverage refrigerator?
Created on: 19 Aug 2020 14:03
dustin44
Hello everyone, I am considering modifying my IKEA Besta cabinet as a built-in solution for a beverage cooler. Specifically, I want to understand which dimensions and mounting options I need to keep in mind for the Besta system to ensure the cooler is securely installed, properly ventilated, and visually well integrated into the furniture. What are your experiences with this kind of conversion? What should I be aware of regarding the electrical connection and selecting a suitable refrigerator when using Besta as the base? Are there common tips for ventilation or installation that I should know about? I appreciate all advice, especially recommendations for built-in coolers that fit well!
Wesley schrieb:
The BESTA cabinet is actually not designed for heavy appliances Thanks, great tip! I was wondering whether I need to reinforce the frame. How did you handle it? Did you simply add an extra base panel, or did you build a completely new internal structure?
ralfsau schrieb:
Ventilation is key. Add ventilation slots at the bottom and top I’ve thought of that as well. Does IKEA offer specific ventilation accessories, or would you just drill holes or cut slots yourselves?
I haven’t chosen a definitive refrigerator yet. Ideally, I want a model with a glass door that can still be installed flush. I’m curious how well that can be done with BESTA.
dustin44 schrieb:
I was actually wondering if I needed to reinforce the frame. How did you do it? Did you simply add an extra base panel or build a completely new internal structure? I reinforced the floor area with a sturdier MDF board placed on top of the original BESTA base panel and also screwed small wooden battens to the side panel. This gave the whole structure significantly more stability without affecting the appearance.
dustin44 schrieb:
Are there any special accessories from IKEA for ventilation? No, IKEA doesn’t offer anything specific for that. I cut ventilation slots with a jigsaw and smoothed the edges carefully. Just make sure the slots aren’t too large so dirt doesn’t fall inside. Then put a thin mesh behind them and that’s it 🙂
BLAKEO schrieb:
The BESTA cabinet is popular, but not necessarily ideal for built-in refrigerators Exactly my opinion! BESTA is more of a lifestyle furniture piece than a true built-in solution. If you really value professional integration, it’s better to opt for kitchen cabinets with appropriate ventilation channels.
Dustin, don’t be fooled by IKEA design; sometimes being practical is better than stylish. Of course, a self-built BESTA built-in is cool and unique – but it comes with compromises.
Gilbert schrieb:
BESTA is more of a lifestyle furniture piece than a true built-in solution Haha, yes Gilbert, exactly! But with some DIY skills and creativity, you can make almost anything fit. That DIY aspect is what makes it so exciting.
And Dustin, if you need professional tips for finishing, don’t hesitate to ask. For example, you can use magnetic catches for the door trim, so the door is removable and the technology stays accessible.
It takes a bit of effort, but the result looks really stylish and more personalized than a standard kitchen.
