ᐅ How do I clean Malm surfaces after renovation?
Created on: 14 May 2022 08:23
Gigliola
I recently managed to set up my Malm furniture with wood veneer again after an extended renovation. Now I’m facing the issue that the surfaces are partly covered with fine renovation dust and also have some light paint or adhesive residues.
Since I don’t want to damage the surfaces, I’m looking for the best way to gently but effectively clean Malm-style surfaces after renovation.
I’m especially interested in whether certain cleaning products or techniques are particularly suitable for cleaning veneered surfaces like these, so that neither the veneer nor the protective layer gets damaged.
Does anyone have experience with removing renovation dust, paint spots, or glue residues from Malm furniture and could possibly recommend a step-by-step procedure or point out common mistakes? Thanks in advance!
Thierryzar
14 May 2022 12:30
Wipe away fine dust and then clean with a damp cloth. For paint stains, try using nail polish remover (acetone-free). Always test beforehand.
PLOMA
14 May 2022 15:18
I would like to add that when dealing with renovation-related dirt, the correct sequence is crucial. First, remove dust and loose debris to avoid scratching the surface with dirt particles.
For dust removal, an anti-static cloth works very well, followed by a light wipe with a mild all-purpose cleaner.
If the surface is sealed (e.g., with clear varnish or melamine resin), it is fairly resistant to water and mild cleaning agents, but chemical solvents should still be used with caution.
For adhesive residues, it is better to gently work with a wooden or plastic spatula and then apply a small amount of isopropanol locally. Always be patient and proceed in small steps.
If you like, feel free to share which cleaning product you have used, so I can offer more specific advice.
Taubi
14 May 2022 16:04
I can also confirm: it is better to avoid aggressive solvents on Malm surfaces. Microfiber cloth and warm water are usually sufficient. For sticky stains, use a mild dishwashing detergent.
Gigliola
15 May 2022 09:12
Domau0 schrieb:
Original Malm furniture made of veneered MDF or particleboard usually has a melamine coating
That’s interesting, I wasn’t sure if it was really veneered – thanks for this important information. It is actually a piece of furniture with a melamine resin coating.
PLOMA schrieb:
For adhesive residues, it’s better to gently work with a wooden or plastic scraper and then use a little isopropanol spot-wise.
How fine should such a scraper be to avoid scratching the surfaces? I’m worried that using a tool that is too hard might damage the coating.
I will first start with a microfiber cloth and water as recommended. Is there a particular composition for the dishwashing detergent solution that has proven especially effective? Thanks to you all in advance, your tips are very helpful!
boelnu
15 May 2022 10:22
Gigliola schrieb:
Is there a specific mixture for the detergent solution that has proven especially effective?
Yes, I usually do it like this: one to two drops of mild detergent in half a liter of lukewarm water. It is important that it contains no strong fragrances or additives like bleach.
Gigliola schrieb:
How fine should a putty knife be to avoid scratching the surfaces?
I mostly use a plastic putty knife, a few millimeters wide, without sharp edges. You can immediately feel if it is too hard. Gentle pressure and always testing with small movements are key. Better to work carefully several times than too roughly once.
Don’t stress too much, it can be done well with patience 🙂
