ᐅ How do I clean Malm furniture when dealing with stubborn dirt?
Created on: 31 Jan 2020 08:34
Jonar
I have several Malm furniture pieces from IKEA at home that I really appreciate, but unfortunately, some stubborn stains have appeared that cannot be removed with a regular damp cloth. The most affected areas are frequently used surfaces, such as tabletops and drawer fronts. My specific question is: What methods or cleaning products would you recommend for effectively cleaning Malm furniture without damaging the surface material when dealing with tough dirt? Are there any tips for particularly problematic stains that don’t come off with water or all-purpose cleaners? Thanks in advance!
Jamalli schrieb:
Therefore, it is better to use pH-neutral cleaners that are matched to the finish structure.Thank you for this important addition. Could you recommend any specific brands or products that have proven effective? I am not very familiar with furniture care products yet.
Jamalli schrieb:
It is therefore better to use pH-neutral cleaners that are adapted to the paint structure.Exactly, that was also my thought about the vinegar tip: use it carefully and sparingly! For pH-neutral cleaners, I recommend furniture care products like "Dr. Schutz Möbelpflege" or "Pledge Multi-Surface Cleaner."
These are especially formulated for painted surfaces and do not contain harsh acids or solvents. With these, you can remove stubborn stains without damaging the material.
Important: After cleaning, wipe the surface with a damp cloth and let it dry.
If there are stains like pen marks or adhesive residues, a special alcohol-based remover can help, but use it cautiously.
Regarding the cleaning of Malm furniture with stubborn dirt, I would like to add:
Malm furniture is usually made of particleboard with a melamine-coated surface or painted MDF. In general, cleaning agents with a neutral pH are preferred.
Mechanical action (such as abrasive sponges or scouring agents) should be avoided, as they can permanently damage the surface.
For stains that cannot be removed with mild cleaning, special plastic and furniture cleaners are available that are silicone-free and gentle.
For oil or grease stains, it is recommended to use a degreasing cleaner first, which should then be wiped off with a damp cloth.
In any case, it is advisable to test any new cleaning solution on a small, hidden area first to avoid color changes.
