ᐅ How do I clean Malm furniture when dealing with stubborn dirt?
Created on: 31 Jan 2020 08:34
JonarHello everyone,
I have several Malm furniture pieces from IKEA at home that I really appreciate, but unfortunately, some stubborn stains have appeared that cannot be removed with a regular damp cloth. The most affected areas are frequently used surfaces, such as tabletops and drawer fronts. My specific question is: What methods or cleaning products would you recommend for effectively cleaning Malm furniture without damaging the surface material when dealing with tough dirt? Are there any tips for particularly problematic stains that don’t come off with water or all-purpose cleaners? Thanks in advance!
Hello Jonar,
Regarding your question about how to clean Malm furniture when dealing with stubborn dirt, here is a brief guide:
1. First, I recommend wiping the surface with a soft cloth and lukewarm water to remove surface dirt.
2. For heavier soiling, you can use a mild soap solution, for example with a few drops of dishwashing liquid in the water. Important: Do not use harsh cleaners, as *Malm* lacquered surfaces are sensitive.
3. Before using stronger agents, test the solution on an inconspicuous area.
4. For stubborn stains, a mixture of water and vinegar (1:1) often works well, which you can gently rub with a microfiber cloth.
5. In more difficult cases, a rubber eraser can sometimes help (typically for ballpoint pen marks), but use it carefully.
6. Finally, wipe everything with clean water and allow it to dry well.
Common mistakes: Scrubbing too hard with abrasive cleaners or using aggressive cleaning agents, which can damage the surface.
I hope this helps!
I hope this helps!
taudi schrieb:
For stubborn stains, a mixture of water and vinegar (1:1), gently rubbed with a microfiber cloth, often works well.Thanks for the tip about the vinegar solution. However, I have concerns that vinegar might damage the surface. Does anyone know if there could be any permanent harm, especially to drawer fronts that are often made of lacquered wood?
Vinegar should be used on chipboard furniture sparingly and always diluted. The surface is coated with lacquer, and too much acid can cause the finish to become dull or peel. I recommend testing on an inconspicuous area before applying it over a large surface.
Alternatively, you can use special furniture cleaners designed for wood or lacquered surfaces, which are less aggressive and tailored to the material’s properties.
A slightly damp sponge with some baking soda can also help with stubborn stains, followed by thorough wiping.
I would like to question the use of vinegar:
From a chemical perspective, acetic acid is a weak acid that can attack the clear coat on furniture surfaces. Especially with prolonged exposure, the finish could become dull or discolored.
Therefore, it is better to use pH-neutral cleaners that are formulated for the finish. Are there any experiences here with specific products that meet these requirements? In my opinion, the advisable approach is not simply to use vinegar, but rather to look for cleaners specifically designed for painted MDF surfaces.
taudi schrieb:.
