Hello everyone, I have noticed color stains on my Malm furniture – specifically on the white surfaces – from things like highlighters, other pens, and sometimes even from clothing abrasion. My question is: What is the best and, above all, gentle way to remove such color stains without damaging the surface? The Malm surfaces are usually melamine-coated, so they should not be treated too aggressively. Are there any proven home remedies or special cleaning products that I can use? And what should definitely be avoided to prevent the furniture from becoming dull or matte? I look forward to your tips and advice!
Drilonus schrieb:
How can I best and gently remove such paint stains without damaging the surface?I completely understand how frustrating it is when stains or paint spots appear, especially on white MALM furniture. I've had the same issue with felt-tip pens – it really makes you feel helpless!
What helped me was starting very gently with a damp microfiber cloth and some mild dish soap. Just use circular motions without pressing hard. If the stain is still visible, I lightly rub over it with a pencil eraser – but very gently, otherwise it can damage the surface.
Sometimes a bit of acetone-based nail polish remover can work, but only apply it precisely to the stain with a cotton swab, never over a large area or leave it on too long! It’s best to test it first on an inconspicuous spot.
I also find it important to rinse the area immediately with water afterward and dry it well to avoid any residue.
Do you have experience with special products or even gentler methods? Maybe others here have softer tips?
Hello Drilonus,
I’m happy to share a simple guide that I often use and have recommended to friends.
1. Preparation: Use a soft microfiber cloth and warm water with a little mild dish soap.
2. Initial Cleaning: Gently wipe the dirty area, never rub or scrub. This is especially important for melamine surfaces to avoid damaging the protective layer.
3. Stubborn Stains: I recommend carefully using a white eraser (such as a Staedtler Mars Plastic). Make sure not to press too hard and always test on a small area first to avoid scratches.
4. Alternative Methods: For stains from felt-tip pens or permanent markers, you can gently use isopropyl alcohol (rubbing alcohol). Lightly moisten a cotton swab, apply it carefully, and dry immediately—do not soak the surface.
5. What to Avoid: Do not use abrasive cleaners, harsh chemicals, or acetone-based nail polish remover directly on the surface, as these can damage it.
6. Finish: After each treatment, wipe with clean water and dry with a soft cloth.
In summary: proceed carefully, always test first in an inconspicuous spot, and avoid putting mechanical or chemical stress on the melamine surface.
I hope this helps!
I hope this helps!
rickey schrieb:
What helped me was starting very gently with a damp microfiber cloth and some mild dish soap.Absolutely, I agree with that! 🙂
I once had the challenge of removing a thick red felt-tip pen stain from my MALM dresser – and yes, I panicked at first 😉. But it actually came off really easily with a soft eraser, and very important: no rushing! Take your time, be gentle and patient 😊.
Guyju schrieb:
Isopropyl alcohol (cleaning alcohol) works.I’ve tried that too, but a tip: use only a small amount and apply it spotwise. Otherwise, it can dull the shiny surface, which you don’t want.
Sometimes rubbing off a bit of hairspray can help (odd, I know), then wipe immediately and let it dry well – but I would only recommend this as a last resort.
In general: it’s best to start with the simplest methods and never use force.
Good luck to everyone cleaning your MALMs!
