ᐅ How do I clean Ikea Platsa furniture for everyday dirt?
Created on: 30 Apr 2021 08:17
lennartnu
Hello everyone, I have had furniture from the Ikea Platsa series in my living room for some time now. Since I use the cabinets daily, surface dirt such as dust, fingerprints, and occasional coffee stains naturally build up regularly. My question is: What is the best way to clean Ikea Platsa furniture to remove everyday dirt without damaging the surface? Which cleaning products are recommended, and are there any tips for handling the furniture to keep it clean and intact in the long term? Thanks in advance for your help!
nubar
2 May 2021 08:17
Landontau schrieb:
Avoid aggressive cleaners such as alcohol, ammonia, or abrasive products, as these can make the surface look dull or damaged.
This is a very important tip. Additionally, I would emphasize that with Ikea Platsa, it is essential to follow the manufacturer’s care instructions. They advise against using abrasive sponges and recommend avoiding aggressive chemicals to prevent damage to the melamine coating.
Furthermore, a neutral, water-based all-purpose cleaner can achieve good results if used at the recommended dilution. For everyday cleaning, wiping with a lightly dampened cloth is often sufficient. This helps avoid unnecessary stress on the material.
Timofa
2 May 2021 19:28
lennartnu schrieb:
How can I best clean Ikea Platsa furniture to remove everyday dirt without damaging the surface?
A humorous answer: Just don’t bump into the furniture, and the surface will stay clean! Joking aside – I also use microfiber cloths and a little soapy water. Some patience helps because gentle movements remove fingerprints and dust much more effectively.
Also, Platsa furniture is quite sturdy, so don’t worry about the cleaning solution as long as it’s not too wet. Regular cleaning definitely helps prevent stubborn stains. 😉
Friedrich
3 May 2021 07:56
This discussion clearly shows that many prefer gentle methods. Since Ikea Platsa furniture is designed for everyday use, I think it is important that maintenance remains simple and practical.
If you’ve ever made a cleaning mistake – like I did some time ago when I used a strong cleaning agent – don’t be discouraged. Over time, you learn what works best. So clean gently and regularly with mild products, and you will enjoy your furniture for a long time.
Thanks to everyone who shares their experiences here!
