ᐅ How do I clean Ikea Platsa furniture for everyday dirt?
Created on: 30 Apr 2021 08:17
lennartnu
lennartnu
30 Apr 2021 08:17
Hello everyone, I have had furniture from the Ikea Platsa series in my living room for some time now. Since I use the cabinets daily, surface dirt such as dust, fingerprints, and occasional coffee stains naturally build up regularly. My question is: What is the best way to clean Ikea Platsa furniture to remove everyday dirt without damaging the surface? Which cleaning products are recommended, and are there any tips for handling the furniture to keep it clean and intact in the long term? Thanks in advance for your help!
Landontau
30 Apr 2021 09:42
Hello lennartnu, your concern is really valid since Platsa furniture is usually made from particleboard with a melamine coating and can therefore be sensitive to improper cleaning agents. Here is a structured suggestion for cleaning everyday dirt:
- First, I recommend regularly wiping with a soft, lint-free cloth or microfiber.
- Use lukewarm water with a mild dish soap solution; do not spray the water directly onto the surface, but dampen the cloth instead.
- This is usually enough for light grease and fingerprint marks.
- Avoid aggressive cleaners such as alcohol, ammonia, or abrasive products, as these can make the surface look dull or damaged.
- For tougher stains, you can use a special furniture care product designed for melamine or laminate surfaces, but always test it first on an inconspicuous spot.
- After cleaning, dry the surfaces with a dry cloth to prevent water spots.
In summary, gentle and regular cleaning is key to minimizing daily wear and keeping the Platsa furniture looking good. Hope this helps!
elgla
30 Apr 2021 12:24
I can easily understand how annoying it is when dust and small stains build up quickly on furniture that is used daily. Especially with IKEA Platsa furniture, I sometimes cleaned too aggressively at first, which wasn’t good for the surface. Your question is important because even affordable furniture requires some care.
I find that establishing a regular routine helps: set aside a few minutes once a week for furniture maintenance. Then, if you just remove the rough dirt daily with a dry cloth, it doesn’t feel overwhelming, and the furniture stays looking good for longer.
If anyone has specific product recommendations, I’d appreciate hearing them. I sometimes use a slightly damp microfiber cloth with a bit of dish soap, but I’m not sure if that’s the best approach.
Traman4
30 Apr 2021 14:55
Avoid using alcohol or abrasive cleaners! Simply use lukewarm water with a little mild dish soap on a microfiber cloth, wipe gently, then dry by rubbing. I have been doing this for years with my Ikea furniture, and it works perfectly.
TEOZAR
1 May 2021 10:03
elgla schrieb:
If anyone has specific product recommendations, I would appreciate it.
I can recommend cleaning wipes designed for laminate surfaces. They are usually formulated to clean gently while leaving a light protective film behind. This prevents streaks or dull spots from forming.
Also, with Platsa furniture, be careful never to use too much water when cleaning. Water should not seep into the edges, as it can penetrate the material and cause swelling. Over time, this leads to damage that cannot be repaired.
My personal advice: Always use a slightly damp cloth, avoid spraying directly onto the furniture, and wipe dry thoroughly afterwards. This method ensures reliable daily cleaning.
GUMARTINA
1 May 2021 11:35
I always use a damp microfiber cloth for cleaning and, if necessary, a small amount of dish soap. It is important to follow up with a dry cloth to prevent water spots or streaks. Simple, effective, and it does not damage the surface.
