ᐅ How do I clean IKEA Besta units with heavy dirt buildup?
Created on: 2 Jan 2023 08:47
Sabin40
Sabin40
2 Jan 2023 08:47
Hello everyone, I have a somewhat special request regarding the cleaning of my IKEA Besta cabinet. Over time, heavy dirt has built up, including greasy stains, partly dried food residues, and dust in the corners. My question is: What cleaning methods and products do you recommend to clean an IKEA Besta gently but effectively, especially with stubborn dirt? It’s important to me to have tips that do not damage the paint or material, as well as advice on home remedies or specific cleaners. I’m looking forward to your experiences and recommendations!
barda6
2 Jan 2023 09:13
Hello Sabin40, I would recommend starting by cleaning with a damp microfiber cloth and some dish soap. For greasy spots, a splash of vinegar in the water helps. However, avoid wiping too wet to prevent moisture from getting into the joints. I would avoid using harsh cleaners.
PeoDaniel
2 Jan 2023 10:05
Hello Sabin40, I completely understand that cleaning heavy dirt can be challenging. It is important to first know the exact material: IKEA Besta is usually made of melamine-coated particleboard or painted surfaces. These surfaces generally do not tolerate abrasive or solvent-based cleaning products.
My suggestion:
- Start by cleaning with a soft cloth and lukewarm water plus a mild soap solution
- For dried-on stains, you could moisten them with a sponge soaked in warm dishwater and let it soak gently
- For stubborn grease, diluted vinegar or a baking soda solution can be used, but only very carefully and after testing in an inconspicuous spot
- Avoid vigorous scrubbing or abrasive cleaners, as they can dull or damage the surface
If there are deeper stains in the corners, fine brushes or a toothbrush can help to loosen dirt without irritating the surface.
SANMAR
2 Jan 2023 11:22
I know the feeling when a cabinet gets really dirty and you wonder if you can clean it properly again. It’s not always easy to find a method that is effective without leaving additional marks.
I also want to encourage you: patience really helps. Maybe you can take your time and tackle it step by step.
Have you already tried a product? How did it work out for you? Were you satisfied or frustrated?
Sometimes it helps to share the problem and get feedback. Don’t worry, you’ll definitely manage it well!
Luciandi
2 Jan 2023 14:17
I want to agree with Sanmar because I can imagine how frustrating this is. The Besta cabinets actually look quite low-maintenance, but when dirt gets really stubborn, it can really test your patience.
A tip from me: I once cleaned larger surfaces with a mixture of warm water and a little dish soap, and then carefully treated the problem areas with a cloth soaked in vinegar. Vinegar helps against grease, but be careful not to damage the surface.
barda6 schrieb:
A splash of vinegar in the water helps with greasy spots.
I can only confirm that! It’s always important to wipe down with clean water after cleaning to make sure no vinegar residue remains.
Wesley
3 Jan 2023 09:04
Hey, I’m very familiar with the issue of crumbs and grease residue with Besta! My secret tip is a soft sponge, lukewarm water with mild dish soap, and finally a dry microfiber cloth to keep everything streak-free and non-sticky.
If you ever have a stubborn mess, try baking powder on a slightly damp sponge. It acts as a gentle abrasive without damaging your cabinet 😄
Things can get messy, but with a bit of humor and the right cleaning routine, it will be perfect again!
