ᐅ How can I install Ikea Metod cabinets when working with limited space?
Created on: 9 Sep 2015 18:07
GermanvinG
Germanvin9 Sep 2015 18:07I plan to install Ikea Metod kitchen cabinets, but I am facing the problem that the available space in my kitchen is very limited. My main question is how to design the assembly and installation of the Metod cabinets in a way that minimizes space usage without compromising stability and functionality. What strategies or tips are there to build the cabinets in a space-saving manner? Are there recommendations for specific modules or a particular installation sequence that help work more efficiently, especially in small kitchens? I look forward to any advice, including pointers on what to pay attention to during the planning stage.
Basically, I recommend first spreading out all the cabinet parts in the intended corner and checking if all the connecting elements are ready at hand. Then assemble the base units, as they provide the best stability. Use the corner modules from Metod, as they take up less space and are particularly space-saving due to their shape.
Regarding space-saving installation of Ikea Metod cabinets in tight spaces, I would like to provide a more detailed approach:
- First, it is advisable to thoroughly measure the entire installation area and draw a floor plan. When doing this, you should consider not only the available space but also any adjacent doors or radiators.
- Metod cabinets can often be customized modularly, for example with shorter side panels or special internal fittings, which offers a lot of flexibility.
- In limited space, I recommend using U- or L-shaped layouts and opting for tall cabinets that create storage space upwards without taking up floor area.
- An important installation strategy is to prepare the individual units so they can be fixed directly to the wall, which saves workspace during assembly.
Typical mistakes I have noticed: people often underestimate the depth of the cabinet fronts and the actual working surface, which can cause installation problems. Therefore, always verify the measurements against actual kitchen use before installation!
Germanvin10 Sep 2015 08:33Sepele schrieb:
If space is limited, I recommend using U- or L-shaped layouts and opting for tall cabinets that provide storage upwards without taking up floor space.Thanks, that’s a good tip! However, I’m concerned about the installation work itself. What assembly sequence do you recommend when working almost directly against the wall and with narrow passage widths? Is there a method that allows for rough assembly first and then fine adjustments afterwards to minimize space loss?
In any case, it is recommended to first build the frame structure of the cabinets and attach the back panels only at the end. This way, the structure remains flexible for minor adjustments directly on the wall. Important: Carefully set all heights before installing the fronts.
Oh, I recently faced a similar challenge myself, and all I can say is: don’t give up! 😊
A great trick for tight spaces is to partially assemble the cabinets on the floor and then carefully tilt them up against the wall, instead of trying to install everything directly inside the narrow niche. Be sure to work with someone else—that makes the process much safer and easier!
Also, make full use of the adjustable legs on Metod cabinets to level out uneven floors without leaving the cabinet crooked or wasting space. This helped me gain a lot of extra room, and my kitchen area feels much more open!
