ᐅ How can I build IKEA Metod cabinets to be sturdy and functional in a limited space?
Created on: 20 Jul 2020 14:23
DRAFRAHello everyone,
I am planning a kitchen and storage solution using IKEA Metod cabinets in a fairly limited space that only allows for restricted width and depth. It is especially important to me to build the cabinets as stable and functional as possible, even though the space is tight and major adjustments are not feasible.
My main question is: How can I build IKEA Metod cabinets in a limited space so that they are not only stable but also optimally usable, without having to compromise on installation, anchoring, or interior fittings?
I look forward to tips on choosing cabinet sizes, effective reinforcements, optimal fixings to floor and wall, and perhaps clever ideas for internal organization that help particularly in small spaces.
Thank you in advance for your support!
When space is limited, choosing the right cabinet size is crucial. My advice is to use as narrow cabinets as possible (e.g., 30 cm (12 inches) wide) and combine them modularly.
For stability, always screw the cabinets to the wall, ideally at the height of the top edge of the cabinet, and additionally secure them at the bottom. If the floor is uneven, it is better to level it with appropriate wedges or shims.
For increased functionality, I would recommend internal drawers or drawers with telescopic slides. These help maximize interior space and make access easier.
Reinforcements are usually not necessary if you follow the exact assembly dimensions and the IKEA instructions, except in cases of unusual loads.
Hello DRAFRA,
I completely understand your question. When space is limited, it is crucial to make smart use of the available dimensions – besides choosing the right cabinet width, the depth and especially the height are also important.
A few points I can share from my own experience and other users with IKEA Metod:
- Reinforce the connections between the cabinets – even though IKEA provides suitable connecting fittings, sometimes an additional screw connection from the inside is worthwhile, especially for narrower cabinets.
- For wall mounting: Make sure the screws go into stable wall areas, preferably into studs. For drywall walls, longer anchors or special holders should be used.
- If the room depth is very limited, you can customize the depth of the Metod cabinets by using shorter top panels – this way you avoid the cabinets sticking out unnecessarily into the room.
- Regarding functionality, try to design the interior fittings flexibly. Pull-out shelves or rotating carousels in corner units greatly improve accessibility.
Could you possibly specify the exact size of the available space? That would help us give more targeted advice on the optimal Metod setup.
PULAU schrieb:I can only agree with this. Especially for tall cabinets, fixing at the top and bottom prevents tipping.
Important for stability: always screw the cabinets to the wall, preferably at the height of the upper cabinet edge, and also fix them at the bottom.
GiRoyce schrieb:
Could you maybe specify the exact size of the available space? That would help us better focus on the ideal Metod set.Thank you for the detailed response! Yes, the space is about 180 cm (71 inches) wide and 60 cm (24 inches) deep, though I can only use about 58 cm (23 inches) in depth because the back wall isn’t completely straight. The room height is approximately 240 cm (94 inches). The floor is covered with somewhat uneven linoleum, and the wall is solid, so it should hold anchors well.
My goal is to create the highest possible storage solution on this narrow surface, with a minimum depth of 40 cm (16 inches) for the cabinets. The Metod cabinets generally come with a maximum depth of 60 cm (24 inches), right?
Also, I’m interested in how to manage clearances for walking paths when the room is small and cabinet doors or drawers sometimes get in the way. Are there any clever tips?
Depth is indeed an important factor. The standard cabinet depth of 60 cm (24 inches) refers to the carcass, but that doesn’t mean you can’t work with smaller dimensions. IKEA also offers elements with depths of 40 or 37 cm (16 or 15 inches) for base cabinets or tall cabinets.
If the floor is uneven, be sure to check with a spirit level and, if necessary, use shims or leveling pads. Otherwise, the cabinet may tilt and wobble.
Regarding functionality: For narrow rooms, I recommend drawers or doors with a soft-close feature to reduce noise and prevent doors from swinging open.
One option is to retrofit sliding doors if possible, or to prefer internal cabinets with drawers instead of traditional doors. This saves space in front of the cabinet for movement.
DRAFRA schrieb:
I am also interested in how to consider walking paths well when the room is small and doors sometimes get in the way of drawers.
DRAFRA schrieb:
How can I build IKEA Metod cabinets in a limited space so they are not only stable but also fully functional, without compromising on assembly, anchoring, or interior fittings?Hi DRAFRA, that sounds like a challenge but also an exciting project!
If I were you, I would focus on making the most of the available height and consider planning the cabinets without handles (using tip-on or handle strips) so nothing protrudes into narrow walkways.
It’s also useful to perfectly level the cabinets if the floor is uneven – IKEA offers small leveling feet for this, but sometimes thin wooden shims you make yourself can help, too.
For stability, angle brackets on the critical inner corners are really valuable. You can’t see them once installed, but they provide a lot of support, especially when building taller units.
Finally, use storage solutions with adjustable compartments to turn even the smallest cabinet into a space-saving wonder. Having some flexibility inside is always a good idea.
Good luck with your project! If you like, please share what you end up installing.
