ᐅ How can I build an open shelving unit with storage using Ikea BESTA?
Created on: 3 Oct 2021 18:27
Mibegi
Mibegi
3 Oct 2021 18:27
Hello everyone, I am planning to modify my Ikea Besta system to create an open shelving combination that also provides storage space. Specifically, I would like to know the best way to achieve this so that the shelving remains stable, visually appealing, and offers practical compartments for storage.
I am envisioning a version where not all elements have doors or drawers, but some are left open to allow air circulation and better visibility. At the same time, there should be enough storage space for books, decorations, and smaller items.
Does anyone have tips on selecting the right BESTA components, arranging the modules, and possibly reinforcing the structure? I would also appreciate any experience related to assembly, combination options, and useful additions such as back panels or shelves.
Thanks in advance for your advice!
LAURE-TA
3 Oct 2021 19:03
Hello Mibegi,
Regarding your concern: The Ikea BESTA series is very well suited for this, as the modules can be combined in many ways and configured with different fronts. For an open shelving combination with storage space, I recommend the following approach:
- Choose open carcasses without doors or with glass or open shelves
- Combine with closed elements, such as drawers or doors, to ensure storage space
- Use back panels only where stability is required; a completely open back can become unstable
- To increase stability, the modules should be screwed together. IKEA supplies suitable connecting elements
- Depending on the ceiling height, you can stack modules (multi-level arrangement); be sure to ensure stable connections and no sagging
- For an open look, glass shelves, which are also available for BESTA, or thicker wooden shelves are suitable
A typical setup would be a base of two to four modules side by side, with additional open modules on top, possibly with doors for storage underneath or on the side.
Common mistakes are usually a lack of fixing the elements to each other and lack of reinforcement of the back panels, which can cause the shelving unit to tip over or become unstable. Additionally, using wall attachments is worthwhile to ensure safety.
If you have exact measurements or photos of the rooms, more targeted suggestions could be made.
I hope this helps for now!
GALENKU
3 Oct 2021 20:16
I would simply recommend:
- Use open cabinet halves
- Install back panels only where stability is needed
- Screw modules together with connecting hardware
- Don’t forget wall mounting
This is usually enough to build a stable open shelving unit.
Ianlau
4 Oct 2021 08:43
LAURE-TA schrieb:
A typical setup might be a base of two to four modules placed side by side, with additional open modules stacked on top, possibly with doors for storage underneath or on the sides.
That’s exactly how I did it at home. For me, it was especially important that all modules were securely connected. This not only provides stability but also creates a uniform overall appearance.
One extra tip: use interior boxes or baskets in the open sections to keep small items organized. This helps avoid a “messy shelf.”
Also, consider adding back panels in neutral colors – they not only offer support but often provide contrast that highlights the shelf contents.
If you plan to build the shelf taller, pay attention to the weight resting on the lower modules and check the load-bearing capacity of the shelves or use additional reinforcements.
Feel free to ask if you have any questions!
GALEO4
5 Oct 2021 14:57
I’m surprised you present this simple insight as a tip, especially since with IKEA shelving units the back panel is often the only and most important source of stability. Without a back panel, the structure quickly becomes wobbly—and even if you screw it together, that does not replace the shear strength provided by the back panel.
In my opinion, with BESTA units you should either choose a fully open shelving unit and accept the limited stability, or commit properly to a design with back panels. Anything else is a half-hearted compromise that will likely cause frustration later on.
Furthermore, I often question the practicality of an open shelving combination when actual storage space is the goal. Open shelves tend to create clutter rather than order, unless you’re a minimalist and use decorations instead of miscellaneous items.
But who says furniture must be purely functional or purely open? Good planning is definitely worth its weight in gold here.
