ᐅ How can I build Ikea Besta as a multifunctional piece of furniture with adjustable compartments?
Created on: 12 Mar 2016 08:23
memonau
Hello everyone, I am planning to use the Ikea Besta system as a multifunctional piece of furniture and want to equip it with adjustable compartments that can be adapted as needed. My goal is to create a flexible solution suitable for open shelves, closed drawers, and spaces for housing electronic devices. I am especially interested in how to design or arrange the dividers and shelves so that the layout can be quickly and easily reconfigured without having to disassemble the entire unit. Are there any proven methods or special tools to keep the compartments both flexible and stable at the same time? I would appreciate any tips, experiences, and possibly recommendations for useful accessories or modifications.
Santiagobu
13 Mar 2016 07:38
Regarding stability: Ikea’s Besta modules typically have sturdy shelves made of particleboard or MDF, reinforced with metal inserts. It is important to observe the maximum load per shelf, which is usually between 10-15 kg (22-33 lbs). If you want adjustable compartment sizes, you can also consider using dividers made of acrylic or thin wood, which can be attached with small screws, magnets, or click systems. This allows for quick reorganization, but the downside is a somewhat higher investment and slightly more effort during installation.
Ventilation for electronics: As mentioned, open compartments are best. However, if you prefer the look of closed compartments, you can use doors with perforated metal or add small ventilation openings at the top and bottom. This keeps devices cool while maintaining an attractive appearance.
Guyju
13 Mar 2016 09:14
Here is a brief guide on how to make your Besta module truly multifunctional and versatile:
- Step 1: Develop a plan. Measure your exact dimensions and list the devices you want to accommodate. Consider their weight and ventilation requirements.
- Step 2: Choose shelves. IKEA typically offers shelves that are 2-3 cm (1 inch) thick; if you need to support more weight, you can also use custom-made shelves with reinforcement.
- Step 3: Dividers. Use removable dividers made of lightweight materials, such as MDF or acrylic, which can be attached with simple plug-in or screw systems. This allows you to quickly create new compartment sizes.
- Step 4: Ventilation. Open compartments or door options with perforated fronts are useful. Alternatively, fans can be installed, preferably with thermostat control to prevent devices from overheating.
- Step 5: Accessories. Use soft-close drawers and front panels that can be mounted flexibly to combine aesthetics and functionality optimally.
A common mistake is underestimating the load capacity of the shelves or neglecting ventilation. This guide helps you avoid those issues.
jokau
14 Mar 2016 08:53
Guyju schrieb:
Use soft-close drawers and adjustable fronts
That’s a good tip. It makes the furniture look more high-quality while keeping it flexible in structure. I would also make sure that all screws and connectors are regularly tightened, especially with frequent rearrangements.
