ᐅ How can I build IKEA BESTA as a low-budget DIY project for custom storage?
Created on: 16 Jan 2021 09:37
Sanismail
Sanismail
16 Jan 2021 09:37
Hello everyone, I am planning to use the IKEA Besta system as a base for a low-budget DIY project to create customized storage space. I am particularly interested in creative and cost-effective ways to modify or enhance the typical components, such as the carcasses and doors, to achieve precise and practical solutions.
I am drawn to the combination of manufacturer-supplied parts and my own craftsmanship—such as adding extra compartments, applying custom finishes, adjusting dimensions, or installing special shelves.
How do you generally approach modifying IKEA BESTA for your own projects? Which materials and tools do you recommend to achieve solid results at a low cost?
Does anyone have tips on challenges to be aware of when customizing BESTA, especially if you don’t have a professional carpentry background but still want an aesthetically pleasing and functional solution?
I look forward to hearing your experiences and ideas!
tangi
16 Jan 2021 10:28
Basically, for a low-budget project with IKEA BESTA, you should pay attention to material choices and tools to keep costs low while ensuring quality work.
I recommend:
- Use the standard modules, as they are usually cheaper and readily available.
- Invest in a good multifunction tool, such as an orbital sander or a router, which will help you with adjustments.
- For custom compartments, affordable MDF boards work well and can be fixed with simple drill holes and brackets.
- For surfaces, spray paint or wood veneer can save both time and money.
- Make sure to measure very precisely to avoid problems during assembly.
The main challenge is stability when making modifications. Be cautious if you remove shelves or carry loads due to adjustments. A strong basic structure is essential for functional storage space.
Genevieve
17 Jan 2021 15:13
tangi schrieb:
Basically, for a low-budget project using IKEA BESTA, you should pay attention to the choice of materials and tools to keep costs low while ensuring clean workmanship.
That is generally true; however, I would critically question how cost-effective it really is to heavily modify IKEA components structurally. Often, the original parts do not provide the necessary stability for individual structural requirements.
For users without carpentry expertise, the temptation is high to create decorative additions rather than precisely fitting components. While this can enhance storage space, it carries risks regarding durability and everyday usability.
Therefore, my question to Sanismail: How important is long-term load-bearing capacity for your custom-built solution? And what is your experience with different materials—particleboard versus MDF versus solid wood?
Without solid basic knowledge, short-term low-budget "tricks" often become more expensive later due to rework or new purchases.
mopra42
18 Jan 2021 08:46
For customized BESTA solutions:
- First, choose modules that best fit your room size.
- Use affordable shelving components for internal partitions.
- Avoid major modifications to the carcass, as stability may be compromised.
- For the finish, paint or veneer is sufficient.
- Tools: cordless drill, jigsaw.
This is often enough for simple, functional adjustments without a large budget.
