I am planning to build a custom-fit bookshelf using the IKEA Besta series. I want to arrange the modules so they fit perfectly into my existing niche with a specific width and height. It is important to me that the shelf is not only sturdy but also precisely adapted to the room dimensions, without requiring much modification or cutting.
My questions are:
- Are there any helpful methods or tools to choose and combine the right Besta modules?
- Which measurements should I take exactly (e.g., width, height, depth) to achieve the best possible fit?
- Do you have any tips regarding assembly, especially when connecting multiple modules to ensure stability?
- Should certain IKEA extensions or accessories be purchased to optimize the construction?
I would greatly appreciate detailed experiences or recommendations to help make this project go as smoothly as possible. Thanks in advance!
My questions are:
Muratmu schrieb:
I am planning to build a custom-fit bookshelf using the IKEA Besta series.To create a custom-fit bookshelf with IKEA Besta, precise planning is essential. Here is a step-by-step guide:
- First, the measuring process is crucial: carefully measure the width, height, and depth of the niche using a laser measure or tape measure. Be sure to account for any unevenness in the walls.
- IKEA Besta modules come in standardized sizes; common widths are 60 cm, 120 cm, and 180 cm, with a typical depth of around 40 cm (16 inches). Custom cutting is not intended for the Besta series, so the module combination must consider this limitation.
- Use the IKEA planning software or other 3D design tools to explore different layouts. This helps to better estimate which modules to combine without risking narrow gaps.
Assembly tips:
- Always use the connection points of the modules; IKEA provides suitable metal connectors and screws. For added stability, it is recommended to secure the modules to the wall.
- To prevent bending under heavy books, shelf boards can be reinforced with additional supports.
Additional options:
- Doors or drawers are available if you want more than just open shelves.
- For a personalized look, glass inserts or other decorative elements can be used.
In conclusion: re-measure the exact dimensions on site before finalizing, as even half a centimeter (0.2 inches) can make the difference between fitting perfectly or not.
Muratmu schrieb:
Which exact measurements should I take (e.g., width, height, depth) to ensure the result fits as precisely as possible?Accurate measurement of the available space is essential. Here is a practical guide:
- Width: Measure at three points (top, middle, bottom) since walls often are not perfectly straight. Use the smallest measurement as the usable width.
- Height: Measure at least at two points to account for uneven floors and ceilings.
- Depth: The Besta modules usually have a depth of 40 cm (16 inches), sometimes 20 cm (8 inches); you should take this into account to avoid any overhang.
Additionally, I strongly recommend allowing a clearance of 1–2 mm (0.04–0.08 inches) on each side during planning. This makes assembly easier later and prevents the unit from getting stuck unintentionally.
Moreover, it is best to rely on the standard Besta dimensions, as custom cuts are rarely possible and the modular system greatly simplifies assembly.
In summary: measure very carefully, take multiple points, consider irregularities, and allow a 1–2 mm (0.04–0.08 inches) tolerance.
PLOMA schrieb:
Use the IKEA planning software or other 3D design software to test different scenarios.That is a very useful tip. I would like to add my experience:
When building a custom-fitted shelf with IKEA Besta, it is important to first verify the actual room dimensions using a proper leveling tool. Even a slight offset or uneven walls can cause significant problems during installation.
A small trick to assemble truly precise modules is the following procedure:
- After measuring, first create a scale drawing or use digital tools to map the niche, including wall irregularities and radiator recesses.
- Then select the Besta modules to achieve the maximum coverage without gaps – often a mix of 60cm (24 inches) and 120cm (47 inches) widths works well.
- Use IKEA’s screws to join the modules, ensuring stability and preventing wobbling later.
I also recommend paying attention to these points during installation:
- Before permanently fixing the modules, do a trial fit to check that everything fits well.
- Use wall fasteners suitable for the wall material, especially with drywall (plasterboard) or older buildings.
- For heavier bookshelves, it can be helpful to reinforce additional shelves with metal brackets.
One more note on accessories: assembly hardware, corner connectors, and matching back panels from the Besta series are essential components to make the construction stable and to ensure the overall project’s durability.
All in all, careful planning and precise measuring are key to achieving an attractive and solid result.
