ᐅ What is the best way to remove price tags from IKEA Hemnes furniture?
Created on: 3 Sep 2022 07:18
Fetole
Fetole
3 Sep 2022 07:18
Hello everyone, I have a problem removing the price tags stuck on IKEA Hemnes furniture. The tags are not only somewhat stubborn to peel off, but they often leave sticky residues that are difficult to remove without damaging the surface. My question is: What methods or products do you use to effectively and gently remove price tags from Hemnes furniture without harming the wood or the finish? I would appreciate any tips, especially regarding tried-and-true home remedies or specialized cleaners.
chenValeri
3 Sep 2022 08:23
I usually take some warm water with dish soap and a microfiber cloth. Soaking often dissolves the adhesive, allowing the label to be cleaned off without damaging the wood.
Davebla
3 Sep 2022 09:12
Interesting, but can this definitely be applied to Hemnes furniture? I ask because many IKEA products have a special coating or finish that might be damaged by water or solvents. Have you tested this? I would also be interested in any experience regarding whether isopropanol or specific adhesive removers would work better in this case. Trying it out without caution could easily cause damage.
Fetole
3 Sep 2022 09:59
Thank you for the tip, @Davebla, that is an important addition. The Hemnes series actually has a matte lacquer finish that is sensitive to solvents. For my first attempt with isopropanol, I tested a small area very carefully. The result was mixed because the solvent can slightly dissolve the lacquer if rubbed for too long. Therefore, I am currently looking for a method that works more mechanically in combination with mild agents. Does anyone have specific experience with this?
flo-Theres
3 Sep 2022 11:26
I have had good results using a combination of a hairdryer and rubbing with oil. The process: Warm the label gently with a hairdryer so that the adhesive underneath softens. Then, use a few drops of olive oil or baby oil on a cloth to carefully rub off the adhesive residues. It is important not to rub too hard to avoid damaging the paint. The oil dissolves the adhesive completely and often also conditions the surface. Afterwards, wipe the area with a cloth and mild soapy water to remove any remaining residue.
LEEJU
3 Sep 2022 12:14
My additional tip: If the adhesive is very stubborn, you can also spray a little WD-40. It effectively dissolves the adhesive, but please use it sparingly and clean thoroughly afterward with soapy water, since WD-40 contains oil.
