ᐅ What is the best way to secure Ikea Platsa units on carpeted flooring?
Created on: 10 Jul 2021 18:07
catalin34C
catalin3410 Jul 2021 18:07Hello everyone, I recently ordered the Ikea Platsa system and plan to install it in my living room on carpeted flooring. Since I read that the Platsa units are mainly mounted to the wall or connected using the supplied fittings, I’m wondering: What is the best way to securely and stably fix this furniture on carpet? My main concern is to prevent any wobbling or shifting under load, as the carpet is softer than a hard floor. Are there any special fastening methods, adhesive strips, or additional structures you would recommend? I appreciate any tips on how to make the system stable on carpeted floors without damaging the carpet or leaving marks.
FRANCISCOP10 Jul 2021 19:43Basically, attaching Ikea Platsa furniture to carpet is challenging because the carpet provides a flexible surface. The Platsa system is modular and designed for planned, solid flooring. To achieve stability, I recommend the following approach:
- First, assemble all modules with the supplied connectors to create a solid unit.
- Then, secure the unit to the wall using the included wall fasteners, if possible. These are intended for flat wall types and provide the most important support.
- There is no official Ikea solution for attaching directly to the carpet itself. In this case, I suggest placing some kind of non-slip underlay or anti-slip pads under the furniture feet. These prevent movement on the carpet without the need for adhesive.
Gluing or drilling into the carpet is generally not advisable, as it does not provide lasting stability and damages the carpet. For additional stability, you could also use small wooden boards as a base under the furniture legs.
FRANCISCOP schrieb:
Gluing or drilling into the carpet is generally not recommended, as it does not provide lasting stability and damages the carpet.I see it somewhat differently: If you do not want to drill permanently into the carpet, you can certainly consider special hook-and-loop tape solutions. These are available with strong enough adhesive power to secure lighter furniture on carpet and can be removed without residue when moving. However, they must be applied carefully, and the piece of furniture should not exert heavy weight or significant leverage forces.
A completely different option would be to place the Platsa system not directly on the carpet but on a thin, stable baseboard (e.g., a plywood sheet), which is firmly and evenly positioned underneath. This significantly improves stability and protects the carpet at the same time. Whether this setup is compatible with the Ikea mounting hardware would need to be checked.
For me, wall mounting is the crucial factor, as secure fixation on carpet alone is not very advisable without it.
I can add that Ikea itself recommends in the assembly instructions for Platsa to connect the modules together and secure them to a solid wall. If that is not possible, a carpet helps prevent slipping – in this case, anti-slip mats work very well when cut to fit under the feet.
Additionally, it should be noted that Platsa does not have significant stiffness: if the modules are properly screwed together and wall-mounted, the carpet should have little effect on stability.
For those who do not have the unit against a wall: one idea is to make the Platsa more stable by weighting it down with heavy items inside the cabinet or installing cross braces at the bottom for additional support. These braces are, of course, not from Ikea but can be custom-made.
Tevin schrieb:
If someone doesn’t have the unit anchored to the wall: One idea would be to add some weight with heavy objects inside the cabinet or install horizontal braces at the bottom for more stability.That’s a great tip!
I also think you can gain some stability by placing weights at the bottom, but be careful: If the pieces are standing alone on a soft carpet, there’s still a risk of tipping over – anchoring to the wall is almost essential, especially for taller shelves or cabinets.
In summary: Carpet means flexibility – it won’t really work without wall fixing or at least very secure support from below (e.g., non-slip mats).
You could almost say: “Platsa on carpet without wall anchoring? As stable as a sandcastle.” 😉
V
vincent4612 Jul 2021 09:03I can understand your concerns about stability. Carpet often makes it difficult to securely fasten furniture. Here’s something I’ve experienced myself: it’s worth positioning the furniture so that normal use—like loading it and opening the doors—causes as little tipping or shifting as possible.
In my case, I placed the Platsa on thick carpet and added felt pads to the feet. This didn’t completely prevent sliding, but it significantly reduced the unpleasant wobbling. Of course, anchoring it to the wall would have provided more security, but that wasn’t an option for me.
My experience is that a combination of secure connections, anti-slip mats, and careful handling of the furniture offers the best balance. I had some doubts at first as well, but this approach allows you to gradually find the best solution without much effort.
