I am planning to mount several Ikea Platsa units on the wall in my apartment. I am especially concerned about securely and neatly attaching the back panels. These back panels are quite thin and made of cardboard, so I’m wondering what the best way is to fix them to the wall without bending or damaging them.
Are there any special tips or proven methods to mount the back panels so that they are strong and durable? What tools and fasteners do you recommend? Should the Platsa back panels be prepared or reinforced in any way before installation?
I would really appreciate detailed advice, especially on how to avoid common beginner mistakes.
Thanks in advance!
Thanks in advance!
Hello bujuix,
I’m happy to help you with this. The PLATSA back panels are indeed somewhat delicate since they are made only from a thin cardboard-plastic composite. Here’s my summary of the best way to handle them:
- Preparation: First, check if the back panels are flat. Small warps can be evened out by carefully applying weight.
- Fastening materials: Small nails about 15 mm (0.6 inches) long work best, thin enough to avoid tearing the back panel. Alternatively, fine staples from a manual stapler can also be used.
- Technique: Place the nails or staples along the edges at short intervals of 10-15 cm (4–6 inches). Don’t pull too tight, or the material will tear! A common mistake is using nails that are too large or thick, which can damage the back panel.
- Reinforcement: If you want to strengthen the back panel, you can use double-sided tape to secure it to the wall or screw a thin wooden board behind the panel, which significantly increases stability.
Important: This should ideally be done on an even wall, as uneven surfaces can cause tension and warp the back panel.
I hope this helps you already! If you have specific situations (e.g., uneven walls), feel free to ask again.
jelite schrieb:
Small nails (about 15mm (0.6 inches) long) that are thin enough to prevent the back panel from splitting work best.That’s a good tip. To add to that: IKEA usually uses a coated hardboard or MDF panel for the back walls of PLATSA units. Although these panels are thin, they are relatively sturdy.
I recommend securing the back panels to the main frame with appropriate wall anchors and screws before installation. Many people overlook this step because the back panel is often just slotted in place.
For wall mounting, the most stable option is to fix the back panel together with the frame to the wall or to use the mounting holes of the frame. This helps avoid overloading the thin back panel.
If you want to attach the unit only through the back panel, it is best to use small, flat nails combined with cover strips or additional reinforcements; otherwise, the stability will be limited.
In summary: using only the back panel as the attachment point to the wall is not the optimal solution.
Interesting perspectives so far. But I wonder: Is it really practical to use the thin back panel as a load-bearing element for mounting?
I agree with that. Even thin nails can eventually pull out under load, especially if the PLATSA units are loaded with heavy items.
My suggestion would be to treat the back panel primarily as a cover, while the main attachment is made through sturdy brackets or mounting strips behind the side panels. This way, the force is distributed onto structural components. The back panel could then be additionally secured with clips.
If anyone has different experiences, I would appreciate examples or evidence.
Enrico4 schrieb:
Using the back panel alone as a mounting point on the wall is not the optimal solution.
Hey everyone!
I recently assembled my PLATSA units and tried the following approach:
- First, I attached the back panels to the carcass using small staples.
- Then — very important for me — I secured the entire unit directly to the wall with suitable corner brackets.
This way, I could be sure that the back panels don’t have to bear much load. The look is great, and everything feels rock solid!
If anyone is unsure: don’t rely solely on the back panel; fix the units at the solid frame points, or you might run into problems later. Good luck!
Pome60 schrieb:
If anyone is still unsure: Don’t rely solely on the back panel, but secure the components to the solid anchoring pointsThat is absolutely correct.
I would like to add that most PLATSA units come with pre-drilled holes in the side and back panels, which are specifically designed to permanently anchor the modules to the wall while also distributing loads.
When these designated fixing points are used, the back panel is preserved in its primary role—as a stability and cover element.
In practice, this means: use suitable screws with appropriate wall plugs for your wall type, and attach the modules not only through the back panel, but via the modular connection points. This way, both the back panel and the furniture piece are properly protected.
