ᐅ What is the best way to attach Ikea PLATSA back panels?
Created on: 31 Aug 2018 08:23
bujuix
I am planning to mount several Ikea Platsa units on the wall in my apartment. I am especially concerned about securely and neatly attaching the back panels. These back panels are quite thin and made of cardboard, so I’m wondering what the best way is to fix them to the wall without bending or damaging them.
Are there any special tips or proven methods to mount the back panels so that they are strong and durable? What tools and fasteners do you recommend? Should the Platsa back panels be prepared or reinforced in any way before installation?
I would really appreciate detailed advice, especially on how to avoid common beginner mistakes.
Thanks in advance!
gekira
2 Sep 2018 14:25
Gerard schrieb:
Use appropriate screws with suitable anchors for your wall type, and fasten the modules not only through the back panel but also at the modular connection points.
I agree with this.
Additionally, I recommend checking the type of wall before installation (drywall, concrete, brick). For drywall, special cavity anchors are advisable; for concrete, use standard expansion anchors or hammer-in anchors.
If you cannot access the area behind the back panel: some users improve stability by attaching a thin plywood or MDF board behind the back panel to provide better screw support.
But as a general rule: use the back panel only as a cover, not as a load-bearing element.
Sheldon
3 Sep 2018 08:03
Attach the backing panels with small nails or staples, use brackets, and screw them from the back of the wall. Done.
