ᐅ How can I prevent damage when transporting Ikea PLATSA units?
Created on: 30 Apr 2024 18:37
naleo55Hello everyone,
I am planning to transport some IKEA Platsa furniture pieces in the next few days — both multiple-module units and individual pieces. I am concerned that the items might get damaged during transport, as the material and construction are somewhat delicate. My question is: What proven methods and tips do you know to effectively prevent damage when transporting IKEA Platsa?
I am especially interested in advice on the best packaging techniques, proper handling during loading and unloading, and which areas to pay extra attention to in order to avoid scratches, breaks, or other damages.
I look forward to your experiences and recommendations!
naleo55 schrieb:
What proven methods and tips do you know to effectively prevent damage during the transport of IKEA PLATSA?That’s a very good question, since PLATSA furniture can be quite delicate due to its construction and relatively thin panels. In general, I would recommend the following:
- Wrap individual parts well in blankets or bubble wrap, as edges and corners are especially vulnerable.
- Store screws and small components in labeled bags to prevent loss or damage to other parts.
- When transporting by car, lay the furniture flat, well-padded at all times. Never stand pieces upright unless they can be securely fixed.
- Ideally, add an extra protective layer, such as cardboard sheets between multiple parts stacked on top of each other.
- Handle loading and unloading carefully to avoid bumping anything against walls or hard surfaces.
I’ve also had good results applying corner protectors on the most exposed sides—they cushion potential impacts quite effectively.
Do you already have a specific transport route or special conditions we should consider?
Kinbu schrieb:
When transporting furniture by car, lay it down flat and always keep it well padded.Exactly! To emphasize the importance of keeping it flat: if you position your PLATSA pieces upright or tilted, they can shift or warp significantly during braking or turns – definitely not ideal.
I always wrap the parts in blankets to soften the surfaces. I also like to place a few towels or even old sweaters between the pieces for extra cushioning.
A little tip that always works for us: use a tape dispenser to secure the foil or blankets gently without sealing everything airtight. This way, you can easily unpack everything later.
Practically, it also helps to have a second person for carrying, to keep the furniture stable – and very important: never transport or turn it upside down!
Good luck, you’ll do great!
naleo55 schrieb:
I am especially interested in tips on optimal packaging, proper handling during loading and unloading, and which areas to pay particular attention to in order to avoid scratches, breaks, or other damage.I think it’s great that you’re thinking about this, as damaging furniture is always frustrating. I once had damage to a PLATSA piece myself because not enough attention was paid to the edges during transport.
What helped me back then was to place everything on a padded surface and protect the corners—using special edge protectors or simply small foam cushions, for example.
When loading and unloading, it’s best to proceed slowly and carefully rather than hastily or without coordination. If possible, lay down protective film to prevent dirt or moisture marks.
One more tip: when assembling the furniture after transport, it’s better to tighten screws and connections gently at first. Sometimes small movements can loosen parts and cause instability instead of stability.
Hope this helps!
