Hello everyone, I am planning a move soon and have some furniture from the Ikea Brimnes series. Although this furniture looks nice and is relatively affordable, I experienced some damage during my last move, such as scratches, chipped edges, and small dents.
My main question is: What options and methods are there to prevent damage to Ikea Brimnes furniture during a move? I mean both mechanical damage from impacts as well as potential issues when disassembling and reassembling. Are there any specific tips for this type of furniture, perhaps recommended padding materials, transport techniques, or tools that work particularly well?
I would appreciate detailed and practical advice to help make this move as damage-free as possible.
The Ikea Brimnes is known for its relatively thin engineered wood panels and is therefore quite sensitive to mechanical stress. To avoid damage during moving, I recommend the following points:
- Fully disassemble all movable parts (drawers, doors): The drawer slides on Brimnes furniture are delicate and should be packed separately.
- Protect the individual parts well with bubble wrap or blankets, especially the edges, which often bend or break.
- Reinforced protection at corners and edges using edge protectors (also available in foam or cardboard) is advisable.
- During transport, keep the furniture flat to prevent twisting and thus cracks.
- Screws and small parts should be labeled in bags and stored securely to facilitate later reassembly.
Thorough preparation significantly reduces the risk of scratches and breaks.
I would like to organize this a bit more clearly and add some practical tips, as I have a lot of experience with Brimnes:
First: Proper preparation for disassembly
- Start by completely emptying and removing the drawers; this makes the furniture lighter and prevents damage to the drawer system.
- Use the included screwdriver to loosen all screws, but be careful not to over-tighten them if using a power drill, as this can cause the furniture material to splinter.
Second: Protection when packing
- Bubble wrap is essential; additionally, I use stiff packing paper to protect larger surfaces from abrasion.
- Wrap corners preferably with cardboard strips, which you can secure with adhesive tape.
Third: Transport technique
- If possible, transport the parts vertically upright. If the parts must lie flat, be sure no heavy items are placed on top.
- Use blankets and straps to secure the furniture during transport.
Summary:
- Complete disassembly including doors and drawers
- Careful labeling and secure storage of screws and small parts
- Thorough protection with appropriate materials, especially at edges
- Careful transport with securing and avoiding stress from other objects.
This procedure has proven to be very reliable for me.
Summary:
I generally agree with the overall approach but would like to add a critical comment: It is often assumed that bubble wrap and edge protectors are sufficient. I wonder if this might be too simplistic for the very thin and fragile panels from Brimnes.
That may be true, but in my opinion, there is a lack of guidance on proper handling during carrying itself. The furniture pieces should definitely be lifted more than once to avoid tilting movements. Frequent tipping while carrying can also cause microcracks that lead to damage later on.
Furthermore, I am surprised that no one has mentioned the option of packing the disassembled parts into sturdy boxes. This would systematically improve protection and reduce shifting. I find it careless to use only blankets or wrap without appropriate packaging solutions.
In conclusion, this approach is insufficient to prevent improper transport, and there is also no clear statement regarding the assembly components and their fastenings: Are the screws checked again after transport? Are there any concrete experiences on this?
gadalu schrieb:
The individual parts should be well protected with bubble wrap or blankets, especially the edges, which often bend or break.
Thank you for all the helpful tips so far, especially for the clear summaries and the critical additions.
Regarding packaging: Up until now, I have only used simple blankets and bubble wrap, but I have also considered using sturdy boxes. Are there any recommendations on what type of boxes to use for Brimnes parts that are not too small and still provide adequate protection?
How large are most of the individual Brimnes parts? I wonder if the effort of obtaining boxes and unpacking the parts again outweighs the benefits.
Regarding checking screws after transport: Since I am fortunately somewhat skilled with tools, I plan to check every connection after the move and tighten if necessary. Are there any tips on which joints require special care to avoid tearing the material?
BAUEVA schrieb:
Also, I wonder why no one here mentions the option of packing the disassembled parts in sturdy cartons.
I can provide a helpful answer regarding boxes:
- Large, flat wardrobe boxes work very well for Ikea Brimnes, such as those commonly used by mail-order companies. These especially provide enough space for complete parts.
- Alternatively, you can buy or rent sturdy furniture boxes of appropriate sizes from hardware stores or moving companies.
- It is important that the boxes are strong enough to withstand mechanical stress during carrying and do not get crushed.
Regarding screws:
- By far, the corners and the joints of the side panels are the most critical points.
- To avoid damage when tightening, screws should be driven in slowly and with moderate torque. A cordless screwdriver without torque control is not ideal here.
- Before assembly, it is advisable to check all threads for tight fit, remove any old wood glue if necessary, and use special wooden plugs or veneer caps for the screw holes if needed.
Additionally, it is useful to have one or two helping hands during assembly to prevent unnecessary stress on individual panels while screwing. This helps protect against breakage.
Regarding screws:
