Good morning everyone, I recently bought an Ikea PAX wardrobe and am now facing the challenge of attaching the doors as quickly and easily as possible. My question to you is: How can I install Ikea PAX doors with minimal effort while ensuring everything is stable, the doors are properly aligned, and I don’t spend too much time adjusting and assembling? I’m particularly interested in whether there are any tricks to make the installation easier or if it’s best to rely on the standard assembly kit. Thanks in advance for your helpful tips!
Hello HIRO69, I would like to add that if you want to work quickly, you should definitely pay attention to the sequence: always attach the hinges to the doors first, then mount the doors to the cabinet. This makes handling much easier.
Also, small tricks like using rubber pads or pieces of cardboard between the door and the cabinet can help to check the alignment during assembly without the doors hanging directly. This helps to avoid unnecessary scratches or pressure marks.
If you have chosen sliding doors, make sure to research thoroughly beforehand, as the installation is quite different.
kulau schrieb:
A crooked base makes installation unnecessarily difficult. Absolutely! I also measured everything carefully first, and then attaching the parts went smoothly. And: don’t be afraid to screw things in! Especially with hinge adjustments, fine-tuning is normal – they really make it easy!
So: keep at it, try a bit, and you’ll have your doors installed in no time. Good luck! 🙂
