Hello everyone, I am currently facing the challenge of mounting Ikea Metod wall cabinets on a plain concrete wall. Since the Metod wall cabinets are quite heavy, especially when fully loaded, I want to make sure the mounting solution is secure and long-lasting, without causing any damage to the wall or the cabinets.
Specifically, I’m interested in which type of anchor (e.g., chemical anchors, expansion anchors, drive anchors) is best suited for this kind of installation, whether there are any special precautions needed during assembly, and if there are any practical experiences from real kitchen installations. I’m also uncertain whether the screws can be inserted directly into the concrete or if pre-drilling with a certain diameter is necessary, and how to best distribute the weight, especially on the Ikea mounting rails.
I’m looking forward to your tips and experiences!
Lanine schrieb:
Are there any other tips on what to consider regarding the positioning of anchor holes on a continuous concrete slab?Yes, placement is important: you should avoid positioning anchors too close to edges or cracks to prevent chipping or brittleness. A minimum distance of at least 10 cm (4 inches) from the edge is recommended.
If you use chemical anchors, these tend to be more tolerant to setting movements, which can be important in cases of minor hairline cracks in the concrete.
From a technical perspective, it is also advisable to place the anchors so that the loads are evenly distributed along the mounting rail. A mixed anchor arrangement can extend the service life—meaning distributed across the rail rather than concentrated at one or two points.
Longer rails are beneficial because they provide more anchoring points.
Summary:
- Distance from edges
- Even distribution of anchors
- Use of longer rails
- Cleaning of drilled holes
Two months ago, I mounted Metod cabinets on concrete walls. I used 10mm (3/8 inch) heavy-duty anchors, a masonry drill bit, and thoroughly cleaned the holes with a brush. Since then, the cabinets have been completely stable without any wobbling.
It is always important that the anchors are fully embedded in the concrete and that the screws are tightened firmly but not over-tightened. You can also use washers on the Metod rails to prevent misalignment.
Pre-drilling with a cordless drill that has a hammer function speeds up the work.
