ᐅ How do I mount Ikea Metod wall cabinets on concrete walls?
Created on: 10 Dec 2018 08:43
Lanine
Lanine
10 Dec 2018 08:43
Hello everyone, I am currently facing the challenge of mounting Ikea Metod wall cabinets on a plain concrete wall. Since the Metod wall cabinets are quite heavy, especially when fully loaded, I want to make sure the mounting solution is secure and long-lasting, without causing any damage to the wall or the cabinets.
Specifically, I’m interested in which type of anchor (e.g., chemical anchors, expansion anchors, drive anchors) is best suited for this kind of installation, whether there are any special precautions needed during assembly, and if there are any practical experiences from real kitchen installations. I’m also uncertain whether the screws can be inserted directly into the concrete or if pre-drilling with a certain diameter is necessary, and how to best distribute the weight, especially on the Ikea mounting rails.
I’m looking forward to your tips and experiences!
besau
10 Dec 2018 09:17
For concrete walls, I recommend using 10mm (0.4 inch) heavy-duty anchors. Pre-drill with a masonry drill bit matching the anchor size, using a depth stop. Screw into the metal mounting rail, then insert the anchors – this provides a very secure hold.
marcosku52
10 Dec 2018 10:26
besau is absolutely right – the appropriate heavy-duty anchors are your best friend here. Take a little extra care when drilling, and the mounting will work perfectly. 😎 And remember: it’s better to drill a bit too large than too small, so the anchor fits well without putting excessive stress on the concrete.
By the way, if you do this kind of work often, it’s worth investing in a cordless drill with a hammer function. It saves your nerves and your muscles! Maybe I’ve had too much coffee today, but I see a proper, sturdy mounting that will easily hold your Metod treasures.
LANICOLE
10 Dec 2018 14:03
I’m happy to add some structure, since this is about achieving a permanent and secure result.
- Stage 1: Preparation
Use a masonry drill bit to drill into the concrete at least as deep as the length of the anchor, ideally a bit deeper to allow the dust to fall out.
- Stage 2: Choosing the anchors
Chemical anchors (injection mortar) are a very reliable option, especially for heavy loads. They bond firmly with the concrete. Alternatively, heavy-duty anchors such as expansion bolts work well if the concrete is in good condition.
- Stage 3: Installation
The cabinet suspensions on the Metod rail systems distribute the load vertically. Screw the rails directly into the wall, positioning the screws into the anchors.
Common mistakes are using anchors that are too small and screws that are too short – I recommend at least 8cm (3 inches) long screws with metric threads M6 or M8, depending on the anchor manufacturer and load requirements.
Additionally: Make sure the drill holes are precisely aligned with the corresponding points on the Metod rail, otherwise you will have problems hanging the cabinets.
Hope this helps!
sihau
11 Dec 2018 07:59
Lanine schrieb:
Specifically, I’m interested in which type of anchor (e.g., chemical anchors, expansion anchors, drive anchors) is best suited for fastening
For a concrete wall, any heavy-duty anchor suitable for the specific concrete density is generally appropriate. However, chemical anchors are advantageous in cases of lower-strength or cracked concrete. They provide higher load capacity through bonding.
Additionally:
- Cleaning the drilled holes with compressed air or a brush before installation is mandatory
- Always pre-drill with a masonry drill bit matching the diameter of the anchor
- Choose the screw length so that the anchor is fully embedded in the concrete
This ensures optimal load distribution for wall cabinets, preventing vibrations and possible material fatigue.
Lanine
11 Dec 2018 14:21
Thank you for this detailed explanation. What about situations where there are already pre-drilled holes in the wall (e.g., from previous fastenings) – is it still possible to use chemical anchors afterwards, or could that negatively affect the load-bearing capacity? Are there any other tips regarding the placement of anchor holes on a continuous concrete slab?
I am also considering whether using longer mounting rails or additional cross braces might help to better distribute the load.
