ᐅ How do I install Ikea Metod doors for soft closing?
Created on: 12 Feb 2020 19:27
LUKIMO
LUKIMO
12 Feb 2020 19:27
I am currently planning to install the doors on my new IKEA Metod kitchen to ensure they close softly. My specific question is: How can I best attach the Metod doors to achieve a smooth, soft-close effect? I understand that IKEA usually provides integrated soft-close hinges, but I am not sure about the optimal way to mount them or if there are additional adjustments to fine-tune the closing process.
Additionally, I am interested in:
- Which steps are particularly important during installation to properly adjust the soft-close function?
- Are there common mistakes to avoid when mounting the doors?
- Do I need any special tools or accessories?
I would appreciate any helpful tips or personal experiences to make sure the doors not only look good but also feel high-quality and last a long time. Thanks in advance!
Jodyro
12 Feb 2020 20:04
The soft-close hinges for IKEA Metod cabinets usually come pre-assembled from the factory. Important points:
- Make sure to snap the hinges in correctly and tighten them securely.
- You can adjust the damping with the small screw on the hinge arm.
- Ensure the door is properly seated on the hinge plate, otherwise it won’t close correctly.
Tools: A Phillips screwdriver is sufficient.
You can avoid mistakes by not overtightening and by aligning the doors before fully securing everything.
SUDAN
13 Feb 2020 08:39
Hello LUKIMO,
I would like to address your question in more detail because correct installation is crucial for a perfect soft-close experience.
1. Preparation:
- First, check if your hinges have an integrated soft-close function. You can identify this by a small damping cap at the end of the hinge pin.
2. Installation:
- Attach the hinges to the door using the screws provided – these usually allow for some adjustment.
- Hang the door by snapping the hinges onto the mounting plates on the cabinet carcass.
3. Adjustment:
- The soft-close damping is often adjustable via a small screw on the hinge mechanism. Depending on whether the door closes too quickly or too slowly, you can fine-tune it by turning the screw a little.
- Warning: If tightened too much, the door may not close properly at all.
4. Common mistakes:
- Over-tightening the screws, which can prevent proper fine adjustment.
- Incorrect door alignment, causing the damping not to engage correctly.
5. Tools:
- A good Phillips screwdriver and possibly an Allen wrench (hex key) if your hinges use different screws.
Summary: Attaching the hinges precisely according to the instructions and adjusting the damping screw are key. Taking your time with door positioning will ensure smooth closing quickly.
Good luck with your kitchen!
JAFUHAU
14 Feb 2020 12:16
SUDAN schrieb:
The soft-close damping can often be adjusted using a small screw on the hinge mechanism.
That’s exactly what I also experienced! At first, I wasn’t sure if it was normal for the doors to sometimes close too quickly or too slowly. With a little fine-tuning, it got better and better.
Jodyro schrieb:
Make sure the door is properly seated on the hinge plate; otherwise, it won’t close correctly.
I can only confirm that. I tried twice to attach the doors somehow, which only led to annoying clicking sounds. When I precisely aligned the door and connected the mat with the hinge, everything became much quieter and the soft-close effect really took effect.
I find it very reassuring when the doors don’t slam but close gently and smoothly. For me, that makes a big difference in the perceived quality of the Ikea Metod kitchen.
If you want, I can also explain exactly how I adjusted it.
