ᐅ How do I securely attach IKEA Metod cabinets to drywall (plasterboard) walls?
Created on: 20 Dec 2016 17:23
pefael
Hello everyone, I would appreciate detailed guidance on securely mounting IKEA Metod cabinets to drywall. My plan is to install several wall cabinets in the kitchen on a drywall partition that is supported only by metal studs. Since the cabinets can become quite heavy when fully loaded, I am wondering how to ensure a strong and durable installation without damaging the wall or risking the cabinets falling off over time. Are there specific fasteners, such as suitable anchors or plugs, that you would particularly recommend? Additionally, I am very interested in whether it might be necessary to install extra reinforcements behind the drywall. I am familiar with basic steps like locating the metal studs, but I am unsure about the best approach when working with IKEA Metod cabinets. Thanks in advance for concrete advice and experiences!
TEKIN
21 Dec 2016 09:04
As a supplement:
- The most practical approach is to mount onto load-bearing material, such as metal studs or an additional wooden substructure.
- Use self-tapping metal screws at least 4.5 x 25 mm (approximately 3/16 x 1 inch) or longer, depending on the wall thickness.
- Hollow wall anchors (e.g., toggle anchors, expansion anchors) provide limited load capacity and are better suited as supplementary support.
- Before installation, determine the spacing of the profiles and prepare suitable fasteners accordingly.
The most important point is to never consider the drywall panel itself as the sole load-bearing element.
RETRAVIS
21 Dec 2016 11:42
In summary:
- IKEA Metod cabinets are designed for wall mounting, but only if the wall is sufficiently load-bearing and stable.
- Drywall alone does not provide a strong enough fixing; therefore, mounting should be done on metal studs or an additional reinforced substructure.
- Load-rated facade anchors or cavity anchors can be used as supplementary support but are not suitable as the sole load-bearing fixation for heavy furniture.
- It is essential to thoroughly check the wall construction and locate the underlying studs before installation.
A secure installation prevents accidents and avoids damage to both the wall and the cabinets.
