ᐅ How do I securely attach IKEA Metod cabinets to drywall (plasterboard) walls?
Created on: 20 Dec 2016 17:23
pefael
pefael
20 Dec 2016 17:23
Hello everyone, I would appreciate detailed guidance on securely mounting IKEA Metod cabinets to drywall. My plan is to install several wall cabinets in the kitchen on a drywall partition that is supported only by metal studs. Since the cabinets can become quite heavy when fully loaded, I am wondering how to ensure a strong and durable installation without damaging the wall or risking the cabinets falling off over time. Are there specific fasteners, such as suitable anchors or plugs, that you would particularly recommend? Additionally, I am very interested in whether it might be necessary to install extra reinforcements behind the drywall. I am familiar with basic steps like locating the metal studs, but I am unsure about the best approach when working with IKEA Metod cabinets. Thanks in advance for concrete advice and experiences!
RETRAVIS
20 Dec 2016 18:07
Regarding the attachment of IKEA Metod cabinets to drywall (gypsum board) walls, the general rule is: drywall panels alone cannot support heavy loads. The feasibility of fastening depends largely on the underlying structure.
- If the metal wall studs (metal profiles) are securely installed and properly spaced, the cabinets should be attached directly to these studs. Self-tapping metal or sheet metal screws that provide sufficient holding power are suitable for this purpose.
- If the wall consists only of drywall and the studs are spaced too far apart, it is advisable to install an additional load-bearing support frame, such as wooden battens or a double stud frame, behind the drywall. This helps to distribute the weight more effectively.
- Alternatively, heavy-duty metal anchors or hollow wall anchors designed for drywall can be used. These are only suitable for lighter cabinets or for supplementary support.
In practice, a combination is often recommended: secure directly to the studs or the added wooden support using appropriate screws, and avoid relying on the drywall itself as a load-bearing surface. This ensures long-term stability under load.
noge58
20 Dec 2016 18:42
Great topic! I recently did exactly that and can only say: go for it! 😊
For me, it worked well to screw the cabinets directly into the metal studs using chipboard screws. The key is to drill the holes accurately to hit the studs – the best way is to use a metal detector. The alternative with wooden battens behind is also excellent; if you have the opportunity, this allows for a very sturdy construction.
I tried using clamp profiles or cavity anchors, but especially for loaded cabinets, I would play it safe and reinforce the substructure instead. In the end, a lot depends on thorough preparation – but once that’s done correctly, it will last forever! Good luck!
Issac_kla2
20 Dec 2016 19:15
It’s interesting how often the crucial structural role of drywall partitions is completely overlooked here.
RETRAVIS schrieb:
Drywall boards alone cannot bear heavy loads.
That’s clear, but I think the strength of stud frame constructions is sometimes overestimated. The studs themselves are thin, and if they are not properly fixed, even the best screw won’t help. I would even question whether IKEA actually provides a genuine recommendation for such constructions.
Maybe it’s better to rely on free-standing furniture or floor-mounted designs when the walls are that fragile. For me, safer construction still involves more than just “see the stud, put in a screw.”
jakar
20 Dec 2016 19:47
Align metal studs and fasten them with self-tapping sheet metal screws, adjusting the screw length according to the screw type.
If the studs are too far apart, attach a wooden batten behind them, drill the drywall on the outside, and screw directly into the wood.
bauku
21 Dec 2016 07:31
Hey, I did exactly the same thing: screwed wooden battens behind the drywall and then attached the cabinets to them! 😊
I can only say: no doubts! With the right preparation, it works perfectly, and the cabinets are firmly secured! If you want, you can also use hollow wall anchors to distribute the load, which gives you even more safety. Good luck with your project!
