I am planning to attach a large mirror to the doors of my Ikea Pax wardrobe. The doors are made of fiberboard with a smooth, painted surface. It is important to me that the mounting is secure without permanently damaging the doors or leaving unsightly holes. Additionally, the mirror should be fixed straight and firmly so that it does not shift or fall off during frequent use. Does anyone have experience with which methods or tools work best? Are there specific brackets, adhesive systems, or mechanical fasteners you would recommend? I look forward to your tips and advice, especially regarding the appropriate approach and materials.
The most reliable option is special mirror brackets that are screwed onto the doors. If you don’t want to drill holes, there are also mirror adhesives or double-sided tapes that provide strong hold, but they are not as secure in the long run. Personally, I would use screws with wall plugs if the doors can support them.
PeoDaniel11 May 2023 14:46Hello Lusonu,
I understand your concerns about the door’s durability. Ikea PAX doors are usually not solid wood, so you should be very careful with screw methods. Here are some proven options:
- Mirror adhesive: Specifically designed for smooth surfaces, strong, but removal can leave marks.
- Strong double-sided mirror tape: Quick and easy, but only recommended for smaller mirrors.
- Screw-on mirror brackets: Very secure, but require small holes. I recommend pre-drilling the holes carefully with a drill set to low speed for wood fiberboard to avoid splitting.
- Alternative: Before installation, screw a thin strip of wood or MDF to the inside of the door (if possible), then attach the mirror to that, which helps distribute the load better.
It is also important that the mirror is not too heavy and that the adhesive or brackets are suitable for the door’s thickness and material.
PeoDaniel schrieb:
Ikea PAX doors are usually not solid wood, so you should be very careful with screw methods. I believe this is the crucial point. Many tend to simply screw or glue things without considering the load-bearing capacity of the surface.
Therefore, I would add:
- Always check the maximum load capacity of the doors. If the mirror is too large or heavy, even the best mounting hardware may cause damage.
- Professional mirror mounting systems that use small screws engaging the inside of the door distribute the load much better than just adhesive.
- If you choose to use adhesive, select products with good elasticity to compensate for stress caused by temperature changes.
In summary: Most damage results from overloading and poor preparation. It’s best to have a plan and understand the door material thoroughly before making a decision.
