ᐅ How do I build an Ikea BESTA unit as a home office cabinet with cable management?
Created on: 30 Mar 2020 18:37
iker63
Hello everyone, I’m planning to build a home office cabinet using the Ikea Besta system, where I can also organize all my cables neatly. The challenge is to integrate a good and clean cable management solution without compromising the appearance or stability. Does anyone have experience on how to do this best? Specifically, I’m interested in tips on installing cable grommets, suitable materials, and how to create optimal storage space for cable organizers or power strips. Thanks in advance for your help!
Mekau
31 Mar 2020 14:06
Attach power strips inside the cabinet, equip cable openings with rubber grommets. Carefully drill the back panel with a hole saw. Cable ducts on the inner sides keep everything organized.
Joe52
1 Apr 2020 09:18
Danabla schrieb:
Mounting the power strip inside the cabinet
I can confirm that—it’s much more convenient and looks neater. In my case, a small LED light strip inside the cabinet also improves visibility without creating a big mess. At first, I had concerns too, but with proper ventilation, it’s not an issue at all. Just do some test runs to check how warm it gets.
What I recommend to everyone: plan for multiple cable openings, even if they remain unused at first. This makes future modifications much easier.
Lilygla
1 Apr 2020 17:39
I’m adding a few details here that might be helpful:
- For drilling holes, a jigsaw with a guide works best. Start by making a pilot hole through the back panel, then cut out the opening. Circular holes can cause thin panels to crack, so it’s better to cut slightly larger and then smooth the edges with an angle grinder, followed by edge protection.
- The cable entry point should be positioned to avoid any tension on the cables. This means easy access to the connections and strain relief using cable ties or Velcro straps attached to the furniture itself.
- When integrating a power strip, it should definitely have child safety features, and avoid loose plug adapters behind the cabinet at all costs, as these can be a serious fire hazard.
- Use pre-installed cable grommets if available from the manufacturer (like Ikea accessories), or opt for universal rubber grommets.
- Sometimes it also helps to install small channels behind the cabinet for the electrical cables, so they don’t rub directly against the wall.
One last question for iker63: Are you planning a modular cabinet expansion, or are the dimensions fixed and unchangeable? This will affect how flexible your cable management can be.
