ᐅ How do I assemble Ikea PLATSA furniture on uneven floors?
Created on: 17 Aug 2023 08:13
MALENA
I recently purchased several Ikea Platsa modules and am now facing a problem during assembly: the floor in my apartment is not completely level but has noticeable unevenness – both across the surface and in the slope. Since I want to build the furniture securely and have it stand safely, I’m wondering what the best approach is to install the Platsa furniture stable and straight despite the uneven floors.
Are there any special techniques that have proven effective for such challenges? Which assembly materials or additional parts would be recommended to prevent tipping or uneven standing? Do I need to level out the floor irregularities first, or can the furniture components be adjusted accordingly?
I would greatly appreciate concrete tips, step-by-step explanations, and practical experience, preferably with advice on what to watch out for specifically when working with Platsa. Thanks in advance!
Josefane
17 Aug 2023 14:27
I find it interesting that so far the discussion has focused almost exclusively on adjusting the furniture, but not on the floor as the foundation.
MALENA schrieb:
The unevenness has a difference of about 7 millimeters over one meter (0.28 inch)
7 millimeters (0.28 inch) is significant and can especially cause problems with laminate flooring, as the material itself is less forgiving than carpet or cork.
From my perspective, it is crucial that the base is correct – if the floor is that sloped, you should consider the long-term effects. Simply adjusting the furniture repeatedly may worsen the problem over time; for example, screws may become stressed or modules may warp.
Therefore, I would recommend preparing the subfloor with a leveling compound or by laying a thin OSB or plywood board on the floor and adjusting it with wedges. The furniture can then be mounted on this. Of course, wall mounting remains very important.
Has anyone had experience with whether the Platsa systems can tolerate such an “underframe solution”? My concerns would be the weight and the attachment of the modules on such a construction.
BOMILAN
17 Aug 2023 15:13
Laminate flooring plus a 7 mm (0.28 inch) difference is not without concerns.
Wedges are the best solution. They can be easily screwed in or fixed with double-sided tape. This prevents them from slipping.
A substructure is labor-intensive and not necessary when using adjustable feet and wall mounting.
Joe52
18 Aug 2023 09:41
MALENA, I really like how you are approaching the problem! People often underestimate how much a slight tilt can affect furniture.
I also wanted to encourage you briefly: For me, attaching the wall mounts was quite a challenge at first because of the uneven floor and the slightly crooked wall. But with patience and small washers behind the brackets, it worked well.
One more tip: Once you have roughly aligned the furniture, keep checking it from time to time, as unnecessary wobbling can creep in otherwise. That can be frustrating—I experienced it myself.
Keep your spirits up, it will work out! 🙂
Marlenepa
18 Aug 2023 12:05
Hello Malena,
another idea: Ikea PLATSA units are quite modular, so you can also place individual sections on smaller bases. In your case, you could try separating the units slightly and fitting them individually with furniture wedges or adjustable feet, instead of assembling the entire system at once.
This often helps to compensate for unevenness individually and reduces pressure on single connection points.
I have done this several times, and it makes leveling much easier, especially when the floor in the room is uneven.
Wishing you good luck!
EDWARD0
19 Aug 2023 07:16
My tip: Use furniture wedges, preferably rubber or plastic wedges that do not slip. Washers or double-sided tape can help secure the wedges further. Use wall mounting, which is important for PLATSA.
