ᐅ How can I arrange Ikea PLATSA furniture space-efficiently in small apartments?
Created on: 12 Mar 2024 08:43
Muleo3
I will soon be moving into a very small apartment (approx. 28 sqm (300 sq ft), one room with an integrated kitchen and a small hallway) and plan to use Ikea Platsa furniture because I appreciate its flexibility and modularity. My goal is to arrange the furniture in a space-saving yet functional way to maximize storage while avoiding a cramped feeling.
Therefore, my specific question is: How can Ikea Platsa furniture be arranged and combined to work best in a small space, especially considering ceiling height, accessibility, and multifunctional use of the elements? What tips do you have for making the best use of smaller wall areas, corners, and niches?
I look forward to your ideas and experiences, including advice on accessories, assembly, or modifications. Thank you!
likuken
12 Mar 2024 14:20
Half-height makes the room feel more open. It’s better to invest in height rather than width. Choose a depth of 35cm (14 inches), otherwise it can quickly become bulky.
theo63
13 Mar 2024 07:25
I would like to add one more point to the discussion about space-saving Platsa configurations: the option to equip modules with casters. This can be helpful if you need to move the furniture occasionally to use the room for multiple purposes.
Also, keep in mind how the opening direction of doors and drawers affects your walking paths, so you don’t create “dead corners” where it becomes difficult to move around the room.
Is it possible to use cabinets in certain places as room dividers, for example? This is often a good compromise between floor space and multifunctionality.
Muleo3
13 Mar 2024 09:07
Filippo schrieb:
I’m curious whether you prefer dresser-style furniture or more floor-to-ceiling cabinets?
Thank you for asking. I tend to prefer floor-to-ceiling cabinets because I want to maximize storage space without taking up too much floor area. However, due to the small floor plan, there isn’t much room for wide furniture when entering the apartment. That’s why the depth and width are very important to me.
theo63 schrieb:
Is it possible to use cabinets in certain places, for example as room dividers?
That could be an option, especially to visually separate the sleeping and living areas. The apartment has an open layout, so some form of room division would be helpful.
Even more: do you have any recommendations for sturdy but not too heavy constructions? I want the furniture piece to be easy to transport, possibly for moves.
pikin
13 Mar 2024 10:44
Full-height cabinets with a depth of 35 cm (14 inches) are recommended. Corner solutions can serve as room dividers without taking up much space. Stability is achieved through wall mounting and high-quality fasteners. For moves, a modular design is advisable, as individual components are easier to transport.
bapar
13 Mar 2024 11:03
Muleo3 schrieb:
Do you have any recommendations for sturdy but not too heavy constructions? I would like to be able to transport the piece more easily during moves.
PLATSA is generally modular and relatively lightweight – the frame is made of particle board with a melamine coating, so the weight is manageable.
For stability, in addition to wall mounting, extra cross braces and avoiding overly wide dimensions help, as narrower modules create less mass and leverage forces.
Another tip: use carrying aids like boxes or bags when unpacking during a move; carrying the individual modules is fairly easy thanks to the clever slot-together system.
Regarding room dividers, a module with open elements works best, as it keeps the space visually larger and brighter.
kaubi
13 Mar 2024 11:50
Muleo3 schrieb:
Even more: Do any of you have recommendations for stable but not too heavy constructions?
Regarding stability combined with low weight:
PLATSA frames are easy to handle because of their design. Keep in mind:
- Avoid unnecessarily wide modules, as this increases the weight
- Wall mounting is mandatory for Titan combinations taller than 1.5 m (5 feet)
- Use metal brackets to additionally reinforce the connection points
- For moving, it is ideal to break down into individual modules since the fronts are also removable
If you want to use the modules as room dividers, install a cross brace at the top right away to ensure stability.
I also recommend, if possible, varying the weight with different interior fittings, storing heavier items at the bottom to improve stability.
