ᐅ How do I install Ikea Metod kitchen cabinets under sloped ceilings?
Created on: 20 Sep 2018 18:37
Sarzar
Sarzar
20 Sep 2018 18:37
I am currently facing the challenge of installing a new kitchen with Ikea Metod cabinets under a very steep sloped ceiling. The kitchen will be fitted in an older building with a slope of about 45 degrees, and I am wondering how to best adapt the cabinets to the angled wall without having to make extensive custom modifications. I am particularly interested in whether Ikea or the community offers proven solutions to integrate the cabinets both securely and aesthetically.
What experiences have you had when installing Metod cabinet units on sloped ceilings? Do you use special connectors or mounting elements? How do you deal with the gaps at the top under the slope (for example, by trimming the wall cabinets, using special panels, or filler pieces)?
I look forward to your advice, tips, and any potential pitfalls I should avoid.
Thank you in advance!
semuneo
20 Sep 2018 19:12
Sarzar schrieb:
What experiences have you had when mounting Metod cabinet modules on sloped ceilings? Do you use special connectors or fasteners? How do you deal with the gaps at the top under the slope (for example, by trimming the upper cabinets, using special trims or filler pieces)?
Hello Sarzar,
I can totally understand your stress with the sloped ceiling – I tried it myself last year and was torn between “modifying or rebuilding.” In the end, I really took the time and cut the cabinets at an angle to fit as closely as possible to the slope. I shortened the side panels and then fixed them with brackets, which held well, but it was quite time-consuming and nerve-wracking.
Regarding gaps, I used flexible wooden cover strips, which I painted to match the color. In my opinion, they look much better than makeshift fillers.
On the other hand, I’ve also heard from people who made custom trims or panels to create a smooth visual effect.
If appearance is important to you, I’d also consider the potential issue of airflow behind the cabinets – so avoid closing everything off completely, otherwise moisture can build up. It’s best to use lightweight and well-ventilated coverings.
I hope this helps a bit. What helped me was to start with a bit of extra space and then make adjustments step by step, so in the end nothing wobbles or is impractical.
parbau
20 Sep 2018 20:04
semuneo schrieb:
I tried it myself last year and was torn between “adapting” or “building new.” In the end, I actually took the time to cut the cabinets with mitre joints to fit them as closely as possible to the slope.
Hey Sarzar and semuneo,
just the idea of cutting cabinets with mitre joints already feels like a little adventure – almost like a DIY quest! 😅
But seriously: For sloped ceilings, I find flat connectors or so-called joining profiles from Ikea quite useful, especially for stable wall mounting. They are actually quite versatile and can help bring cabinets flush with the slope – though I can’t say from experience if they work well at 45 degrees.
If you don’t want to do too much cutting, you might also consider deeper cabinets that fill light gaps, or instead of full wall cabinets, simply install open shelves – these often adapt better visually to a slope since they’re easier to trim.
And yes, cover panels are my secret tip! Definitely screwed on, not just glued, so you stay flexible. Maybe even with a slight angled edge so it doesn’t look too crude.
Good luck – remember, this kind of work needs patience and a gentle hand. And most importantly, don’t panic: In the end, it always turns out better than expected!
MATHIASDO
21 Sep 2018 07:55
Sarzar schrieb:
What experiences have you had when installing Metod cabinet modules on sloped ceilings?
I find it difficult to understand why the focus is often on "adjusting cabinet modules" instead of questioning the overall kitchen design concept. With a 45-degree sloped ceiling, the first question is whether standard dimensions even make sense.
Sarzar, how much flexibility do you have regarding cabinet height and depth? The Metod series is flexible, but cutting or mechanical adjustments can lead to stability issues, for example, when supports or drill holes are modified.
Perhaps a combination of Metod base cabinets with a custom sloped ceiling cover above shelves or open wall cabinets would be more efficient. Rigid modification of wall cabinets with angled cuts may provide a visually pleasing result in the short term but can cause problems in the medium term, such as when installing doors and locks.
I recommend taking floor plans and room layouts with precise length and angle measurements, then using planning software—including options available from Ikea—to explore different variants. This way, it becomes clear whether height offsets require special cover panels or even custom adjustments.
Just a thought: sometimes less is more when cabinets are thoughtfully segmented and combined with accessories.
O
onron
22 Sep 2018 09:13
MATHIASDO schrieb:
A rigid adjustment of the upper cabinets with cutouts may provide a visually acceptable result in the short term, but it can lead to problems later on, for example with the installation of doors and locks.
That is an important point.
I have experience with Metod cabinets on a 38-degree (38°) roof slope: Sawing and modifying the cabinet sides should only be done where it does not affect structural stability. It is best to preserve continuous drill holes and mounting points.
A practical solution for sloped ceilings are so-called angled panels or end panels, which can be purchased inexpensively at a hardware store or cut from HDF boards yourself. These provide a clean appearance and prevent stress on the cabinet edges.
Also, using brackets and special profiles, the distance to the slope can be adjusted to allow air circulation. This helps prevent moisture damage.
My recommendation: Carefully list all measurements of the countertop length, cabinet width, height, and depth, and sketch the slope including its angles. This makes installation more manageable.
Finally, I suggest assembling the cabinets completely first, placing them against the wall, and then making the adjustments to fit the slope—rather than adjusting first and assembling afterward.
