ᐅ How do I assemble IKEA Metod cabinets with adjustable shelves?
Created on: 9 Sep 2018 08:43
Dazar
Dazar
9 Sep 2018 08:43
Good morning everyone,
I am planning to assemble several IKEA Metod base cabinets with adjustable shelves, but I have some questions about the exact procedure to avoid mistakes. My main question is: How do I properly assemble IKEA Metod cabinets with adjustable shelves so that the shelves hold securely, are stable, and can be easily adjusted when needed? I have noticed that the cabinets usually come with pre-drilled holes for the shelf supports, but I am unsure which option works best for adjustable shelves and what to watch out for during installation.
I am also interested in the best approach if you want to frequently adjust the shelves during use without damaging the holes or losing stability. Tips on the correct placement of shelf supports, materials, or preventing excessive load on the shelves are also welcome.
Thanks in advance for your advice and any specific installation tips!
Isabel
9 Sep 2018 09:27
For IKEA Metod cabinets, simply insert the adjustable shelf supports into the pre-drilled holes. Make sure all the shelf supports are at the same height so that the shelf will sit level later on. You can then place the shelves onto the supports and remove or reposition them as needed.
devon9
9 Sep 2018 11:03
Additional information:
When assembling the IKEA Metod cabinets with adjustable shelves, I recommend the following structured approach:
- First, check the drill holes in the cabinet carcass: these are spaced at regular intervals, usually in a 32mm (1.26 inches) system. This allows for flexible height adjustments.
- Insert the shelf supports so that they are exactly at the same height on the opposite side panels. Even a slight angle or height difference significantly reduces stability.
- Use only the supplied shelf supports, as these are designed to fit the hole spacing and support the weight of the Metod shelves.
- Carefully place the shelf on the supports and check that it lies flat.
- Adjustable shelves should not be overloaded; IKEA recommends a maximum of 25 kg (55 lbs) per shelf. For heavier loads, additional supports or a fixed, screwed-in shelf should be used.
Common mistakes are:
- Incorrect insertion of shelf supports (angled or in the wrong hole)
- Uneven height of the supports
- Excess weight on adjustable shelves
If shelves will be repositioned frequently, it is advisable to prefer shelf supports with a smooth spring action (if available) to avoid damaging the drill holes.
O
ONRONA
9 Sep 2018 13:17
I would like to raise a critical question regarding the whole adjustability concept of the Metod shelves. Sure, the holes in the grid pattern provide flexibility, but how durable is this system with frequent repositioning? The holes are only in the thin carcass, often made of particleboard; repeated removal and reinsertion of the shelf supports can wear out the drill holes. This leads to less secure support and ultimately to instability.
devon9 schrieb:
Anyone who wants to change the position of the shelves frequently should prefer shelf supports with an easy-moving spring function (if available) to avoid damage to the drill holes.
That sounds sensible, but where does IKEA get these supports from? Are they standard or more of an accessory? Also, are there alternatives that are more modular or robust, like hanging systems with metal profiles? I am interested in how you assess the lifespan of the system if I want to change the shelf positions every few months, for example.
Bautau
10 Sep 2018 07:55
On the subject of durability and stability:
IKEA Metod cabinets use a standardized 32 mm drilling system, which has been established in the furniture industry for decades. The drilled holes are usually reinforced with plastic bushings that help distribute the load on the shelf supports.
With careful use and typical repositioning (fewer than 10 times per year), loosening of the holes is rarely an issue. However, if the number of adjustments increases significantly, the holes can wear out further, since particleboard is naturally prone to damage.
An alternative for more frequent adjustments could be installing separate metal shelf support profiles mounted on the back panel or side walls, into which the shelves are hooked. These improve stability and prevent continuous stress on the edges of the drilled holes.
In summary:
- The IKEA system is sufficient for normal repositioning.
- For permanent and more frequent repositioning, metal profiles or fixed shelves should be used.
- Load should be kept as even as possible and within the recommended 25 kg (55 lbs) per shelf.
fugolo
10 Sep 2018 12:21
I would like to provide a brief step-by-step guide to make assembling the Metod cabinets with adjustable shelves easier:
1. Preparations
- Make sure all components are complete and undamaged.
- Sort the shelf supports and check if there are different types (some models use different supports for fixed or adjustable shelves).
2. Inserting the shelf supports
- Select the desired height by using the holes arranged in a 32 mm (1.26 inch) grid.
- Insert the shelf supports straight and fully into the opposite side panels.
3. Placing the shelf
- Carefully place the shelf onto the supports.
- Use a spirit level to check that the shelf is level.
4. Checking the assembly
- If possible, secure the shelves with the included locking clips or screws, if provided.
5. Adjustability
- To adjust the shelves later, lift the shelf, pull out the supports, and insert them into new holes. Avoid using force or swinging motions when removing the supports to prevent damaging the holes.
Summary:
Success depends especially on inserting the shelf supports correctly and evenly, and not exceeding the maximum weight per shelf. Frequent adjustments under normal use are generally not an issue but should be done carefully.
