ᐅ How can I assemble IKEA Brimnes furniture so that it is sturdy and stable?
Created on: 3 Jul 2023 08:23
arjen-le
I recently purchased several pieces of furniture from the IKEA Brimnes series, including a bed and a chest of drawers, and I am currently assembling them. However, I feel that the structure is not as stable as I would like. My specific question is: How can I assemble IKEA Brimnes furniture to ensure it is both durable under load and stands firmly without wobbling? Are there any special techniques or tools I should use? I already have some experience with furniture assembly but want to focus particularly on stability. It would also be helpful if you could point out common mistakes to avoid during assembly.
Dopoki
5 Jul 2023 08:03
Genevieve schrieb:
IKEA designs their furniture so that it is stable using the included tools and following the instructions.
This is generally true; however, the material used in Brimnes is not solid wood but MDF with a veneer, which, combined with the relatively thin back panel and the connector system, results in lower torsional rigidity. Therefore, the correct positioning and full insertion of the wooden dowels is crucial, as they bear the tensile forces.
Jeanbar schrieb:
First, tighten all screws by hand until they are snug once all parts are joined, then progressively tighten all screws in stages.
I also recommend this approach to avoid material deformation. For the back panel, precise alignment and fastening is important because it significantly contributes to stability. Additional wall anchoring greatly increases safety and prevents unwanted tipping or wobbling.
rekijan
5 Jul 2023 11:22
I really appreciate how factual and helpful the discussion is here! 😊 My experience with Brimnes: Always organize all small parts carefully and pre-align all screws briefly with a suitable screwdriver before assembly – this makes them fit more easily later and ensures stability, even under slight strain. Also, definitely secure the bed at the head and foot ends (for example, with the included metal clips). Without the back panel and appropriate bracket elements, it can be quite wobbly. And honestly: sometimes having a friend to hold and adjust things helps a lot, especially if you’re working alone on the construction site. Muscle power combined with a good eye usually results in a strong, stable outcome!
