ᐅ How can I assemble IKEA Brimnes furniture so that it is sturdy and stable?
Created on: 3 Jul 2023 08:23
arjen-le
arjen-le
3 Jul 2023 08:23
I recently purchased several pieces of furniture from the IKEA Brimnes series, including a bed and a chest of drawers, and I am currently assembling them. However, I feel that the structure is not as stable as I would like. My specific question is: How can I assemble IKEA Brimnes furniture to ensure it is both durable under load and stands firmly without wobbling? Are there any special techniques or tools I should use? I already have some experience with furniture assembly but want to focus particularly on stability. It would also be helpful if you could point out common mistakes to avoid during assembly.
meGreg
3 Jul 2023 09:04
That is a really good and important question! IKEA furniture is often designed to be assembled quickly and easily, which unfortunately sometimes comes at the expense of stability. From my experience with the Brimnes series, it helps a lot to initially tighten all screws only by hand and then systematically retighten everything at the end – this reduces stress and ensures more even stability. The included wooden dowels should never be replaced or omitted! I also always keep a small rubber mallet handy to gently and precisely fit the wooden dowels. 🙂 Whenever possible, I assemble the furniture on a soft surface to avoid damage while screwing. If you like, I’m happy to share some tips on how to pay special attention to stability at the common stress points.
V
vinpau
3 Jul 2023 12:37
Great that you brought up this topic! I had the same issue with my Brimnes bed. Here are a few tips that really helped me: - Always screw in with a gentle touch; overtightening can make the material brittle. - Use a cordless drill with adjustable torque settings to control the screw turning precisely. - Assemble the bed on a flat, stable surface to ensure everything fits correctly. - For extra stability, you can attach small corner brackets to the back panels if you're a bit handy with tools! Just be prepared that assembly might take a little longer sometimes, but it’s definitely worth it 😊!!
Genevieve
3 Jul 2023 14:51
I would like to briefly question the necessity of these "extra tools" like rubber mallets or angle brackets for the Brimnes system. IKEA designs their furniture to be stable using only the included tools and following the instructions. If it isn’t stable, the material or design should be reconsidered. In my view, any instability is more likely due to incorrect assembly or screws being tightened too much or too loosely. Are there reliable experiences or well-founded advice on this? Sometimes it also helps to carefully review the instructions again, especially at points where the components are subjected to tension or compression.
Jeanbar
4 Jul 2023 07:19
Hello arjen-le, I understand your concern very well and can assure you that stability with Brimnes furniture can definitely be achieved if you follow a systematic approach. My recommendations: - Thoroughly inspect all parts before assembly, checking for any warping or damaged edges. - Insert the pre-made dowels precisely into the designated drill holes, as they are crucial for stability. - Tighten screws only by hand at first once all parts are connected, then gradually fully tighten all screws step by step. - If possible, securely attach the dresser or bed to the wall; there are usually holes provided for this. - For back panels, make sure they rest flat and fully against the surface, as this improves stability. Would you like more advice on tools or the assembly sequence? I’m happy to help!
gauvin37
4 Jul 2023 10:48
Brief and clear: Don’t just tighten the screws, but also fully insert the wooden dowels. Use a rubber mallet for the dowels. The back panel must be properly secured, as it provides the most stability. Finally, fix the furniture to the wall, especially the bed and cabinets.
