ᐅ How can I adjust Billy cabinet doors so that they close quietly and move smoothly?
Created on: 10 Feb 2021 18:11
rulira
Hello everyone, I have an IKEA Billy bookcase with doors that unfortunately don’t close as quietly and smoothly as I would like. Specifically, the doors sometimes stick, make noises when closing, and overall feel quite stiff.
My question to the community is: How can I adjust the Billy doors so they close quietly and open and close easily and smoothly? Are there specific adjustment points on the hinges, or would improvements mainly come from replacing the seals or hinges?
I have already tried adjusting the screws on the hinges but am unsure about the best way to fine-tune it. Thanks in advance for your helpful tips!
LIELCHEN
11 Feb 2021 10:52
To be honest, the whole issue with Billy bookcase doors is greatly exaggerated. Sure, the hinges can be adjusted, but fundamentally they are low-cost furniture components. I think we often overestimate the product and underestimate how much the design is limited at this price point.
jélite schrieb:
Fine-tuning the three adjustment screws combined with light lubrication and, if needed, small damping elements.
Technically true, but if you want the doors to operate smoothly for years, it will be difficult without replacing the hinges or upgrading with higher-quality components.
By the way: Many people react negatively to soft or quiet closing because they then don’t notice if the door is properly shut. Smooth operation yes, but for me, a bit of a crisp closing sound is part of the furniture’s character. Just my opinion 🙂
reoleon47
11 Feb 2021 12:07
LIELCHEN schrieb:
Honestly, the whole Billy door issue is really overrated.
Well, I actually think the opposite! Especially because the Billy is so popular, you shouldn’t annoy it with constant banging 😄
jélite schrieb:
Tip: If you hear door hinges squeaking, you can attach small felt or rubber bumpers to the cabinet frame
That tip is brilliant! I did the same on my doors, and suddenly all the noise disappeared. An investment of just a few cents really makes a big difference!
Quiet doors simply make living spaces feel better. So, for those who own one: don’t let the cheapness factor discourage you—get your tools out and enjoy! 🙂
blapau
11 Feb 2021 14:15
I would like to add the following regarding the adjustment of Billy cabinet doors: In addition to alignment and lubrication, the quality of the hinges is also crucial. These wear out over time, especially with frequent use.
If a door continues to stick or make noises despite correct adjustment and lubrication, replacing the hinges can be a good solution. IKEA offers compatible replacement parts that can significantly improve functionality.
Another point: Check the boxes and contact surfaces inside the cabinet for unevenness, foreign objects, or slight deformations. These can hinder movement and cause noise.
Finally, it helps not to overload the doors, as excessive weight puts additional strain on the hinges and their adjustment.
Overall, I recommend a systematic approach: check the screws, adjust, lubricate, and if necessary, replace parts.
rulira
12 Feb 2021 09:43
Thank you very much for the numerous and very helpful responses! I have carefully reviewed all the suggestions and will proceed step by step with fine-tuning the hinges, trying out the three adjustment screws.
The tip about using felt or rubber buffers also sounds interesting, especially if you want to soften the closing action a bit. I had been hesitant about lubrication so far, but based on your recommendations, I will apply a drop to the hinge.
@LIELCHEN: I also find your perspective intriguing—you can't expect too much from inexpensive furniture. Still, I believe that with a little fine-tuning, a significant improvement in quality is possible. Let’s see if I can confirm your theory about the "slightly crisp closing" feeling.
I will be happy to share a brief report once I have tried this out. Thanks again to the community for the great tips! 🙂
