ᐅ How can Ikea BRIMNES cabinets be assembled quickly and easily?
Created on: 22 Jan 2020 09:13
AnrianHello everyone, I am currently planning a project to assemble one or more Ikea Brimnes cabinets and am looking for tips and tricks to make the process quick and easy. I have already gone through the instructions, but sometimes there are little hacks or helpful tools that can make the whole process much easier. I am especially interested in whether there are specific methods that make the assembly more organized and time-saving, or if there are particular steps where extra care is needed to avoid mistakes. Perhaps you also have recommendations regarding the tools to use or advice about common pitfalls during assembly. I appreciate any experiences and practical advice!
Hello Anrian, I have assembled several BRIMNES cabinets and would like to share a clear guide on how to save time and avoid mistakes.
- First: Sort all parts and screws by type and assembly step. This way, you can quickly find what you need and prevent mix-ups.
- Use a cordless drill with adjustable torque to avoid over-tightening or under-tightening the screws – this helps prevent damage.
- Follow the instructions exactly, but always double-check the hinge steps to ensure you install the hinges on the correct right or left side; otherwise, the door alignment won’t be correct.
- When assembling the back panel: Place the cabinet body on a soft surface to avoid damage and speed up the process.
- For the drawers, it’s best to first assemble all the bottom wooden parts to keep track of everything.
Summary: Preparation is key. Always work carefully, don’t rush, and double-check before tightening screws.
Hey Anrian, great question! I love assembling furniture like this, and the BRIMNES is really a cool project. 😊
Here are some tips that have always helped me a lot:
- Clear a really large workspace before you start so you can lay everything out and organize it.
- It’s best to involve a second person! It makes the process much more enjoyable and goes a lot faster!
- Stay patient, even if a step takes longer than expected—it’s definitely worth it!
- For the screws: I like to use a magnetized screwdriver so they don’t fall off—saves a lot of annoying searching.
And very important: look forward to your new piece of furniture, it’s super motivating! Good luck, you’ve got this!
Thanks in advance for the tips!
@PRA64, what exactly do you mean by soft substrate on the back wall? Do you use anything specific for that? I’m also wondering if it makes more sense to install the back wall right at the beginning or rather at the end, so it’s easier to access the interior parts?
@Davidleo, the idea of having a second person sounds good! But I’ll probably try it alone since no one is available at the moment. In that case, is there anything I should pay special attention to?
Anrian schrieb:
@PRA64, what exactly do you mean by a soft surface for the back panel? Do you use something specific for that? I often use a blanket or an old mat as a soft surface, which prevents scratching the cabinet surface or the back panel. This protects against pressure marks during assembly.
Anrian schrieb:
And I’m also wondering whether it makes sense to install the back panel right at the beginning or rather at the end to have better access to the interior parts? I recommend fitting the back panel at the end, as this makes all other assembly steps easier without anything being in the way. Additionally, the back panel stabilizes the entire carcass when installed last.
Anrian schrieb:
@Davidleo, the idea of having a second person sounds good! But I’ll probably try on my own since no one is available at the moment. Is there anything I should pay special attention to in this case? Make sure to store heavy parts safely and use aids like a stool or a table to bring items to working height—this protects your back and makes it easier to work alone.
