ᐅ How can you identify quality issues with Ikea Hemnes furniture?
Created on: 8 Aug 2022 10:23
Farmi36
Farmi36
8 Aug 2022 10:23
I am currently considering purchasing several Ikea Hemnes furniture pieces and want to make sure I don’t overlook any potential quality issues before buying. The Hemnes series is known for its solid wood and traditional design, but I have come across some reports of manufacturing defects and long-term problems.
My specific question is: How can visible quality issues be reliably identified in Ikea Hemnes furniture right after unpacking or shortly after assembly, without waiting for signs of wear?
I would appreciate any advice on common weak points or materials that tend to cause problems in this series. Tips on how to properly check the surface finish, wood density, or joint components would also be very helpful.
Thank you in advance for your expertise!
Ryder35
8 Aug 2022 11:07
When unpacking, pay special attention to any rough surfaces and cracks in the wood. Screw connections must be tight and not loose. Also check the fit of the connections between drawers and side panels for accuracy.
Nofege
8 Aug 2022 13:41
As an addition:
- Carefully inspect the surface for paint chips and uneven color tones. Hemnes is solid pine wood, but the paint application may vary in thickness.
- Check the boards for warping—bends or gaps along the edges are common weak points.
- Follow the assembly instructions closely; otherwise, screws may remain loose, reducing stability.
If you are already assembling, take the time to pull the drawers out several times. Jerking, scraping, or sticking indicates poor workmanship or distortion. These points help identify potential defects early.
BOMILAN
8 Aug 2022 15:18
I would primarily pay attention to the quality of the corner joints. Loose connections are more common with Hemnes. Also, avoid applying too much pressure during assembly, as the wood can splinter.
letar
9 Aug 2022 08:44
Ryder35 schrieb:
When unpacking, you should especially look out for uneven surfaces and cracks in the wood.
A more precise addition to this observation: Small hairline cracks in the wood are often visible, especially along the edges of the product and around the areas where the screw holes have been drilled. While these do not pose an immediate risk, they can affect stability if they grow larger.
Furthermore, I recommend checking the weight of the product. For the Hemnes series, the piece of furniture should generally feel solid and not lightweight. A product that feels too light may indicate low-quality materials or poor craftsmanship.
Finally, inspecting the cabinet doors and drawers for an exact fit is essential. Uneven gaps or stiff movement are clear signs of quality issues.
toril
9 Aug 2022 17:29
I agree and would add that with Hemnes, the varying wood grain prevents all surfaces from looking identical. However, defects can be identified by
- thick, visibly uneven paint layers
- noticeable surface irregularities or glue residues
- and especially, drawer slides should be checked to ensure they operate smoothly without resistance.
These indicators help detect poor quality or sloppy workmanship.
