ᐅ How can you easily adjust the doors of an Ikea Hemnes wardrobe?
Created on: 13 Jan 2020 18:27
O
ondidan
Hello everyone, I recently assembled an Ikea Hemnes wardrobe and noticed that the doors seem slightly warped or don’t fit quite right. My question is: How can the Ikea Hemnes wardrobe doors be easily and effectively adjusted so they close flush without gaps or misalignment? Are there specific adjustment options on the hinges or any tricks to fix this with minimal effort? I would appreciate any tips or experiences regarding the exact procedure.
putan
14 Jan 2020 15:59
ondidan schrieb:
Are there any special adjustment options on the hinges here or tricks to get everything back in shape without much effort?
Oh yes, the “magic” screws on Ikea cabinets! 😅 Just take a Phillips screwdriver, turn a little to the left or right, and the doors will nicely align again. My tip: Don’t adjust too much at once, better do it step by step – it’s like dancing, one big move can throw you off rhythm! And another trick: when you take the door off, you can also clean the hinges. Dust or light dirt can also cause real problems.
RABLA
14 Jan 2020 16:18
The doors on the Hemnes cabinet can be adjusted vertically, horizontally, and in distance from the body using the three screws on the hinge. I have done this several times. The important thing is to proceed slowly and check after each small adjustment. Then it works perfectly.
parbau
15 Jan 2020 09:34
onMarcos schrieb:
Common mistakes:
- Applying too much force at once.
- Ignoring the sequence of screws.
- Not checking if the base is level.
That hits the nail on the head! Plus, my favorite saying: “Good things take time.” Sometimes it takes a bit longer, but with patience and enjoyment, you end up creating real furniture masterpieces! And if the neighbors watch you assembling your cabinets, just smile – you’re on your way to becoming a furniture pro. 😉
