ᐅ How can the Ikea Pax system be converted into shoe storage?
Created on: 12 Sep 2023 08:37
MIMIN
MIMIN
12 Sep 2023 08:37
Hello everyone, I am currently considering how to effectively convert my Ikea Pax wardrobe into shoe storage. Specifically, I want to organize the interior space so that I can easily store different types of footwear – from sneakers and ankle boots to sturdy winter boots – in an orderly way. The following points are important to me:
- Flexible storage space that can be adjusted according to shoe size
- A clear and easy-to-navigate arrangement to quickly find the pair I need
- Optimal use of the wardrobe’s height without wasting much space
- A simple implementation using Ikea’s own accessories or minimal DIY work
Does anyone have experience or practical tips on how to rearrange a Pax wardrobe with shelves, shoe compartments, or possibly additional inserts? Are there special tricks for ensuring stability, especially when storing heavy shoes? I appreciate all suggestions!
Palenar
12 Sep 2023 12:53
Good start, MIMIN – your question is quite comprehensive, so I want to go into some detail.
Basically, I recommend using a combination of shelves and special shoe holders or pull-out inserts for shoes. Ikea itself does not offer dedicated shoe racks for Pax, but:
- 1. Shelves: You should arrange these using the flexible peg holes of the Pax system so that you can also accommodate half boots well – meaning slightly larger vertical spacing on the lower shelves and less spacing in the upper area for sneakers.
- 2. Shoe boxes or organizers: Integrate boxes with clear fronts (for example, SKUBB boxes) for everyday or sports shoes. This provides quick access and keeps things organized.
- 3. Pull-out trays or wire baskets: These can help you make better use of the wardrobe depth without shoes getting lost at the back.
Regarding stability: Especially with heavy boots, if the standard shelves seem thin, consider replacing them with stronger boards or adding additional reinforcements.
Do you want to modify only the inside of the wardrobe, or are you also thinking about removing or modifying the doors to improve visibility? Depending on this, we can recommend different concepts.
Also: How many pairs of shoes do you want to store in total? That helps to tailor the planning more precisely.
anken
12 Sep 2023 15:28
I would also recommend paying attention to shortened shelves that do not use the full depth of the Pax wardrobe. This way, items are less likely to slip, and shoes stand more securely.
Palenar schrieb:
Pull-out trays or wire baskets: These can help you make better use of the wardrobe’s depth without shoes getting lost at the back.
That’s an important point. Especially in deeper wardrobes, many shoes tend to get pushed to the back or it becomes difficult to keep things organized.
A practical arrangement by shoe type can also help a lot—sports shoes at the bottom, more formal shoes higher up, etc. And don’t forget to use small hooks or specialized straps on the inside of the doors, so you can hang individual pairs and make the most of the available space.
Tobias
13 Sep 2023 09:44
Quickly implemented: Use the typical Pax shelves and insert a few Kallax units (for smaller compartments); they fit well and provide more stability for shoes.
This saves homemade solutions and keeps the wardrobe flexible.
Laukau5
14 Sep 2023 20:11
To effectively convert the Ikea Pax into shoe storage, you should focus not only on capacity but also on ergonomics and shoe protection. The following approach has worked well for me:
- Taking measurements: Measure the internal dimensions of your Pax carefully, including the depth. This is crucial because many shoes are narrower at the front and wider at the back.
- Shelf planning: Use adjustable shelves reinforced with spacers to prevent sagging boards under heavy shoes.
- Specialized compartments: Use different compartment sizes for sneakers, ankle boots, and tall boots. Tall boots require 40-50 cm (15.7-19.7 inches) of height, while sneakers often need only 15-20 cm (5.9-7.9 inches).
- Shoe drawers: Although Ikea does not offer specific shoe drawers for the Pax, you can buy simple drawer inserts and line them with foam or felt to prevent scratches.
- Air circulation: Ensure the shoes are not packed too tightly and allow some air space at the back so that damp shoes don’t develop odors.
- Accessories: If you want to go beyond the original setups, installing LED lighting at the top inside the unit can improve visibility.
- Doors: If you frequently open the closet, consider replacing the standard hinged doors with sliding doors, as these require less clearance when opened.
My question to you: How much space do you have available, and are the shoes stored in a normal indoor climate? For damp environments, stronger ventilation should be planned.
