ᐅ How can the back panel detachment of BILLY bookshelves be prevented?
Created on: 11 Oct 2021 08:24
Abbaan
Good morning everyone, I’m currently having the following issue with my Billy shelves: the backing board loosens slightly after some time, causing the shelf to lose stability and the backing to fit poorly. This seems to happen especially at the lower parts, where either the wood or the fasteners give way. I suspect that either the nails or the fixing methods are not optimal, or the backing material itself is not strong enough for the load.
I’m particularly interested in effective methods to prevent the backing of a Billy shelf from loosening. Are there any technical accessories, installation tips, or practical adjustments that have proven successful? I’m looking for a permanent solution that can be implemented without major specialized tools.
Thanks for your insights and advice!
Abbaan
12 Oct 2021 09:33
Takutau schrieb:
In my experience, attaching the back panel with longer, thin nails works well, which I first pre-drill slightly
Thanks for the tip about pre-drilling. That caution definitely seems necessary, especially since I read somewhere that the back panels are relatively thin and can break easily.
SUBEN60 schrieb:
Instead of nails, use Loctite screws with small washer heads; these distribute the pressure more evenly
How does that work in practice regarding cleanliness? The temperatures around my heating system are quite high. Does the material hold up well with screw fastenings in the long term, or could fatigue still occur?
I am leaning towards a combination of pre-drilling, screws, and possibly construction adhesive – but I don’t want a complicated solution that will be difficult to dismantle later.
barda6
12 Oct 2021 11:17
Most effective: attach the back panel with screws, pre-drilling thin pilot holes for this. Use mounting adhesive sparingly, if at all. Spacers under the shelf help reduce moisture and heat exposure.
