ᐅ How can the back panel detachment of BILLY bookshelves be prevented?
Created on: 11 Oct 2021 08:24
Abbaan
Abbaan
11 Oct 2021 08:24
Good morning everyone, I’m currently having the following issue with my Billy shelves: the backing board loosens slightly after some time, causing the shelf to lose stability and the backing to fit poorly. This seems to happen especially at the lower parts, where either the wood or the fasteners give way. I suspect that either the nails or the fixing methods are not optimal, or the backing material itself is not strong enough for the load.
I’m particularly interested in effective methods to prevent the backing of a Billy shelf from loosening. Are there any technical accessories, installation tips, or practical adjustments that have proven successful? I’m looking for a permanent solution that can be implemented without major specialized tools.
Thanks for your insights and advice!
Laukau5
11 Oct 2021 09:12
Hello Abbaan,
First of all, thank you for the detailed description of the problem; this makes it much easier to provide targeted advice.
The issue with the back panel coming loose on BILLY shelves is indeed a common one, especially when the shelves are frequently moved or loaded with heavier items. The original thin nails or staples IKEA uses are often not strong enough because the back panel is usually made of thin fiberboard. Over time, this tends to tear out or warp.
A proven method is to replace the original nails with small screws and appropriate washers. This prevents the screws from pulling through the thin particleboard and loosening again immediately. It is important to countersink the back panel first (so the screw heads sit flush or recessed) and not to use screws that are too thick to avoid damaging the back panel.
Alternatively, the back panel can be glued to the inside of the cabinet using mounting adhesive, in addition to the screws. However, caution is advised here: the adhesive should not be too strong, as this would make it difficult to remove the back panel if necessary.
It is also important to apply this combination on all four sides—especially along the lower edges, where the stress is usually greatest.
One more question: is your shelf standing on an uneven floor, or are there any moisture sources nearby? Both can further affect the stability and durability of the back panel.
Abbaan
11 Oct 2021 10:05
Laukau5 schrieb:
The original thin nails or staples that IKEA uses are often not sturdy enough
That sounds plausible to me, as I actually noticed that some nails were dented or loose in certain spots.
Laukau5 schrieb:
Is your shelf standing on an uneven floor or are there any sources of moisture nearby?
The shelf is positioned quite evenly, but it is near a heater. I wonder if the increased heat could have a negative effect, perhaps on the material of the back panel or the stability of the fastenings? Maybe the heat makes the material more brittle or causes the nails to come loose?
koneo
11 Oct 2021 11:27
Hello Abbaan,
Your observation regarding the proximity to the heating unit is important. Wood-based materials, such as the back panels of BILLY shelves, do indeed react to temperature and humidity fluctuations. The usually thin hardboard can undergo slight movements over time, which may loosen nails or staples.
What you could try is carefully removing the back panel from the nails first and then gluing it with a high-quality wood adhesive. Afterward, secure it additionally with screws. Wood glue provides a strong bond that better accommodates thermal movement.
Also, small spacer feet under the shelf can help prevent direct heat from reaching the back panel from below.
One more tip: lightly sand the back panel with fine sandpaper to remove any unevenness – this will help it sit more snugly against the cabinet.
If you like, I can also provide some product recommendations for screws and glue!
SUBEN60
11 Oct 2021 14:14
Abbaan schrieb:
I wonder if the increased heat could potentially have negative effects
In short: Yes, heat can affect stability. The back panels of BILLY bookcases are usually made of thin hardboard, which is hygroscopic – meaning it absorbs and releases moisture, causing swelling and shrinking movements. The material can fatigue at high temperatures and develop cracks at the points where it is fastened.
Laukau5 schrieb:
Fix adhesive on the back of the carcass
This is a useful addition, but it is essential to ensure the adhesive is suitable for wood-based materials and does not react aggressively with the material.
A technical tip: Instead of nails, use Loctite screws with small washer heads; these distribute pressure better and reduce the risk of pulling out.
Additionally, a thin plywood panel can be used as a replacement for the back panel if the original one is too thin or damaged. Plywood has better structural properties and lasts longer.
Takutau
12 Oct 2021 07:51
I often encounter the problem of the back panels coming loose on BILLY shelves, especially when moving the shelves around or storing several heavy books. What has worked well for me is securing the back panel with longer, thin nails, which I first pre-drill slightly. This prevents the back panel from splitting or swelling when hammering in the nails.
In addition, I apply double-sided tape along the edges on the back side to prevent slipping and provide additional stability. It may sound simple, but it noticeably improves the hold.
It is important not to use too much force and to distribute the fastenings evenly on all sides – this minimizes stress.
If you hear noises when sliding the shelf, foam rubber pads under the feet can help keep the shelf quiet and reduce stress on the back panel.
