ᐅ How can I prevent screws from tearing out of BILLY shelves?
Created on: 22 Jan 2018 08:37
Chensin
I recently bought a Billy bookshelf from IKEA and unfortunately noticed that several screws started to strip, pull out, or simply wouldn’t tighten properly during assembly. The bookshelf is mainly intended for books, so it will be loaded with quite some weight.
My question is: How can I prevent the screws in BILLY bookshelves from stripping or pulling out, especially on the side panels or at the joints? Are there specific techniques, screws, or additional aids that provide long-term stability?
I have considered using individual dowels or reinforced screws, but I’m unsure what is practical and truly effective. Your experience or tips would be very helpful!
Thanks in advance!
PRAPI
23 Jan 2018 12:04
A technical solution I can recommend is using so-called self-tapping threaded inserts or screw-in threaded inserts for particleboard.
These can be screwed into pre-drilled holes and provide significantly more holding power than regular particleboard screws. Screws can then be screwed into these sturdy connectors.
Additionally, it is advisable to pre-drill with a smaller drill bit to avoid splitting the material, and to secure damaged holes further with wood glue.
lechen
24 Jan 2018 08:18
Wood glue into the hole, let it dry briefly, then insert the screw. Most cracks occur due to excessive pressure when tightening.
PIERCE
24 Jan 2018 10:02
If screws frequently come loose, reinforcement with small metal plates or brackets that can be attached on the inside can help. This distributes the load more evenly.
LuMarcel43
25 Jan 2018 11:19
PRAPI schrieb:
Using so-called self-tapping threaded inserts or screw-in threads for particle boards
This is definitely a practical approach. Permanently fastening with prefabricated metal nuts also significantly increases stability.
I also recommend regularly checking the screws to ensure they remain tight, as particle boards can slightly expand or contract with changes in moisture.
For those who like to experiment: When assembling BILLY, you can pre-drill the holes using a narrow strip of fabric or paper tape to protect the wood material from tearing too much.
tadi31
25 Jan 2018 14:54
LuMarcel43 schrieb:
You can also pre-drill the holes on BILLY using a narrow strip of fabric or paper tape
This is indeed a useful technique, often applied with furniture screws. Simply stick a layer of tape on the spot before drilling. This reduces the chipping of the particleboard.
I would also like to add that using screws with a larger diameter, if possible, improves strength. But be sure to maintain a consistently secure fit!
I hope these tips help you.
