ᐅ How can Malm bed frames be reinforced after assembly?
Created on: 16 Mar 2020 19:27
Sonfra37
Sonfra37
16 Mar 2020 19:27
Hello everyone, some time ago I bought a Malm bed frame from IKEA, but despite careful use, I have noticed that it loses stability over time. In particular, the sleeping surface feels somewhat unstable, and I would like to reinforce the bed afterward to make it last longer and reliably support heavier loads.
I am especially interested in options to strengthen the Malm bed frame without completely disassembling it or making significant modifications. Does anyone know of suitable reinforcement methods, materials, or additional components that can be easily retrofitted?
It is important to me that the overall stability is significantly improved, especially the crossbars and the sleeping surface – what actually works, and what should I pay attention to?
Thanks in advance for your tips and experiences!
laureo
17 Mar 2020 07:42
Sonfra37 schrieb:
I am especially interested in ways to reinforce the Malm bed frame without completely taking it apart or making major modifications.
This limitation is important, as significantly improving stability usually involves work on the frame and crossbars.
First, I would check the existing screws and brackets and, if necessary, replace or supplement them with high-quality metal brackets or reinforcement plates. Using sturdy center beams made of hardwood or metal can greatly strengthen the middle area of the bed’s support.
A proven method is to add extra crossbars that are directly screwed into the bed frame. You can also replace the slats with stronger versions or use a plywood board if there is no longer sufficient support from the slatted base.
It is important to choose good-quality screws, preferably with a slightly longer thread and self-locking features to prevent loosening. The wood used for any additions should also be strong to ensure the anchor points do not pull out.
If you like, I can provide specific recommendations for materials and sources suitable for such reinforcements later.
Tommy38
17 Mar 2020 10:39
Hello Sonfra37,
The issue with IKEA Malm beds is often that the side panels and cross members are fairly thin and tend to weaken at the joints over time.
I recommend removing the slatted bed base completely and having a continuous plywood sheet (approximately 18 mm thick) cut to cover the entire lying surface. You should place this sheet on the cross beams or, even better, on additional center supports if your bed doesn’t have any. This will distribute the weight much more evenly.
Adding a center beam with suitable brackets or screws on the underside also greatly increases stability and prevents the frame from warping.
Please make sure to tighten the screws with a cordless drill using firm but not excessive torque to avoid damaging the wood. If available, I also suggest using washers under the screw heads to prevent pressure marks.
One more tip: If heavier weight is frequently applied in practice (e.g., at the foot or sides), it might be worthwhile to install metal brackets on the inside corners to prevent the side panels from warping.
SETHBLA
17 Mar 2020 13:14
laureo schrieb:
A proven method is to install additional cross beams
I can confirm that.
I would also recommend checking the central beam and, if necessary, replacing it with a thick squared timber. That makes a big difference.
Tommy38 schrieb:
Have plywood sheets (about 18mm (0.7 inches) thick) cut to size
That holds better than individual planks; I’ve done that myself.
BEMAU
18 Mar 2020 09:06
For retrofitting Malm bed frames to improve stability, I recommend the following approach, which is based on enhancing the structural strength of the sleeping surface and reinforcing the connection points:
1. Stabilize the cross beams:
Malm beds often have cross braces that are undersized. It is advisable to install additional cross beams made of hardwood or aluminum profiles on the underside. Pay close attention to precise positioning and secure fastening with screws.
2. Add or reinforce the center support beam:
If there is no center support beam, one should definitely be added. If a beam is already present, ensure it is strong enough or replace it with a solid wood beam.
3. Improve the sleeping surface:
The slatted bed base can be supported by a sturdy plywood panel resting on the cross beams, creating a continuous load-bearing surface. Alternatively, a compatible slatted base with a more robust design can be used.
4. Check connection points:
Inspect all screws and wooden dowels to make sure they are tight. Secure any loose joints using wood glue and appropriate screws.
Also, watch for corrosion or damage to metal fittings to ensure long-lasting stability.
These measures require some basic DIY skills but can be done without major structural modifications and significantly improve bed frame stability.
