ᐅ How can Ikea PAX wardrobes be used for the organized storage of electronic devices?
Created on: 4 Jul 2015 18:37
EmersonHello everyone,
I am currently exploring how to best use Ikea PAX wardrobes for neat and secure storage of electronic devices.
Many of us have various devices—ranging from laptops, tablets, and consoles to cables, chargers, external hard drives, and other accessories—that often end up scattered and untidy.
I am particularly interested in how to create a system with PAX that provides storage both for larger devices and for small, delicate components. What internal layouts, drawers, inserts, or additions are practical, and what precautions should be taken to protect devices from dust, scratches, or tangled cables?
Any advice on suitable materials inside the wardrobe, ventilation, or cable management options would also be appreciated.
Thank you in advance for your tips and experiences!
For storing electronic devices using Ikea PAX, I recommend focusing especially on modular inserts and interior fittings.
- Flat pull-outs with padded compartments or foam inserts are suitable for laptops and larger devices to prevent scratches.
- Small electronics like routers, external hard drives, or chargers can be well organized in drawers with dividers.
- Cable management can be improved with cable grommets and power strips installed inside the cabinet.
- Ventilation is important for active devices—therefore, installing ventilation grills or even small fans is advisable.
- Materials should be scratch-resistant and easy to clean, for example, with felt or plastic inserts.
Overall, due to its high customization options, PAX offers very good possibilities for electronic device storage when the interior layout is well planned.
draleo schrieb:
For using Ikea PAX for technical equipment, I recommend focusing especially on modular inserts and internal fittings.I agree with that. Additionally, I would suggest considering replacing or adapting the back panels of the PAX units with perforated boards. This greatly improves ventilation and cable management.
When setting up the unit, it is also important to store heavy devices near the bottom to enhance stability.
Another recommendation is to use power strips with surge protection inside the cabinet to operate or charge equipment safely.
Common PAX components such as internal drawers, metal baskets, drawer inserts, and clothes rails can often be repurposed to help organize the space.
I would like to discuss this topic in more detail because I have been using PAX wardrobes for my tech storage for several years.
Basically, the PAX frame provides a solid basic structure that can be easily customized to meet the needs of tech-dependent users with high-quality interior fittings. In my opinion, the key points are:
- Planning the layout: for example, shelf-like compartments for tablets or eReaders that are well padded.
- Using pull-out drawers with soft-close mechanisms so that sensitive devices are stored gently.
- For cables and accessories, boxes with transparent windows or removable organizers that can be easily sorted within the drawers are suitable.
- If you store active tech devices such as Wi-Fi routers or switches, it is essential to ensure good ventilation. In my wardrobe, I cut small ventilation slots and installed a quiet USB fan.
- Additionally, I would recommend planning fixed power outlets inside the wardrobe or at least using mobile power strips with cable management channels to keep cables out of the way.
It is important not to just shove the tech in, but to create an organizational and protective system that ensures long-term functionality and safety.
I am happy to answer any questions on this.
MAVERICKKA5 Jul 2015 12:11Lenfa schrieb:
It is important not to simply install the equipment, but to develop an organized and protective system that ensures long-term functionality and safety.I see this as a crucial point. However, I wonder if the Ikea PAX system is truly optimal for this purpose, particularly since it was primarily designed for clothing storage.
- Are there any experiences regarding how stable and load-bearing the drawers are for heavy technical devices like gaming consoles?
- Is adequate ventilation actually achievable, or does this require significant modification?
I get the impression that for a perfect solution, it might be better to consider specialized furniture specifically developed for housing technical equipment.
Of course, the adaptability of PAX is an advantage, but its disadvantages should not be overlooked.
Regarding the discussion on using Ikea PAX for neat storage of electronic devices, I would like to provide a brief guide:
1. Inventory analysis:
- Which devices (size, weight, heat generation)?
- How often are the devices used?
2. Planning the layout:
- For heavy or valuable devices, a base cabinet with reinforced shelves is recommended.
- For small items, drawers with dividers or boxes help keep things organized.
3. Protection and cushioning:
- Foam or felt inserts on shelves and inside drawers prevent scratches.
4. Cable management:
- Install cable pass-throughs in the back panel of the cabinet.
- Integrate hook-and-loop fasteners or cable ties.
5. Ventilation:
- Use ventilation grilles, especially with active devices, to avoid overheating.
6. Power supply:
- Install surge protector strips inside the cabinet.
Summary: The flexible PAX system allows extensive customization. However, careful planning and technical adaptations are essential.
5. Ventilation:
6. Power supply:
