ᐅ How can the Ikea Pax system be used for storing electronic devices?
Created on: 29 Apr 2019 14:03
Sogupo
Sogupo
29 Apr 2019 14:03
Hello everyone, I am facing the challenge of organizing and safely storing my various electronic devices. Some time ago, I came across the Ikea Pax wardrobe and wonder how to best use this modular cabinet for storing electronics. I am not only thinking about storing cables, consoles, or routers, but also more sensitive devices like external hard drives, cameras, and smaller audio or studio equipment. How can the Pax be set up in the most efficient way, including ventilation considerations, to ensure both dust protection and adequate air circulation? Are there any experiences with specific modifications or accessories to make the cabinet electromagnetically suitable or at least shielded? I look forward to tips, experiences, and creative solutions!
Mekau
29 Apr 2019 14:18
It is best to use shelves and separate compartments for the appliances. This way, you keep things organized and the devices are well protected. Ventilation can be achieved with small ventilation grilles or holes at the bottom and top.
ritotar
29 Apr 2019 14:42
I set up my Pax similarly: cables stored in labeled boxes, devices placed on shelves with enough space for air circulation. A small USB fan provides fresh airflow inside the cabinet. It works great and is even fun to organize! 😄
GUSTAVO56
29 Apr 2019 15:07
The main challenge when using the Ikea Pax wardrobe for electronics is finding the right balance between dust protection and ventilation. Here are a few important points to consider:
- Device placement: Position heat-generating devices closer to ventilation grilles or pre-drilled openings.
- Use breathable storage boxes or compartments to prevent overheating.
- Optionally, a small power supply with temperature-controlled fans can be installed that activate automatically.
- For sensitive electronics like cameras, maintaining a low humidity environment is recommended. Dehumidifiers could be helpful in this case.
- Electromagnetic shielding is difficult since the Pax is made of wood and plastic. Special shielding mats could be installed, but this is quite complex.
I’m curious: Which devices and how many do you plan to store specifically? This greatly affects the necessary measures.
Kabau
29 Apr 2019 15:22
For electronics, it is worth drilling additional ventilation holes on the sides or top. It is best to organize cables in cable boxes, which makes everything more tidy and manageable.
Genevieve
29 Apr 2019 16:01
I share this concern. Assuming such shielding is possible seems mistaken, especially for furniture primarily designed for clothing. It might be better to focus on temperature and dust control. Therefore, I would suggest considering high-quality airtight containers rather than shielding.
It should also be clarified: Is protection against electromagnetic fields or physical influences more important? This would significantly change the approach.
