ᐅ How can the Ikea PAX system be used as a cabinet for technical equipment?
Created on: 31 May 2021 07:34
ANDREJ56
I am currently exploring how to use the Ikea PAX wardrobe not only as a traditional closet but specifically for housing technical equipment. My main questions are:
- How can effective ventilation be created inside to prevent devices like routers, consoles, or small PC systems from overheating?
- What modifications or additions to the basic structure would be useful, such as holes for cable routing or built-in spaces for power strips?
- How can proper cable management be implemented inside the wardrobe to minimize cable clutter and electromagnetic interference?
- Are there any recommendations regarding material protection, for example fire safety or vibration isolation?
I look forward to your suggestions, practical tips, and experiences from those of you who have successfully used the PAX wardrobe as a tech unit in living spaces. Thank you in advance!
ryan1 schrieb:
I installed small USB fans that are very quiet and keep my consoles from overheating.That is a practical solution, but it's important to also include effective dust filtration. Without filters, the cabinet will get quite dirty inside over time, which can damage the devices in the long run.
nojaus schrieb:
Sometimes I get a bit stressed about cable management.I agree with that. Additionally, it’s important not only to bundle cables but also to monitor the load on the power outlets. I often see overloaded circuits in these kinds of setups.
In general, I would recommend not forcing every electronic device into the PAX unit, but only those with low heat output and minimal operational needs.
theo63 schrieb:
This is a good practical solution, but it should also include effective dust filtration.That’s exactly what I wanted to point out as well. A fine dust filter on the ventilation openings is very useful and can even be cut and attached by yourself.
theo63 schrieb:
I often see overloads in such modifications.Additionally, a smart power strip can help keep track and automatically switch off devices when needed.
One final tip: line the inner surfaces with reflective material or thin aluminum foil – this helps with heat dissipation.
