ᐅ How can the Ikea PAX system be used as a cabinet for technical equipment?
Created on: 31 May 2021 07:34
ANDREJ56Hello everyone,
I am currently exploring how to use the Ikea PAX wardrobe not only as a traditional closet but specifically for housing technical equipment. My main questions are:
- How can effective ventilation be created inside to prevent devices like routers, consoles, or small PC systems from overheating?
- What modifications or additions to the basic structure would be useful, such as holes for cable routing or built-in spaces for power strips?
- How can proper cable management be implemented inside the wardrobe to minimize cable clutter and electromagnetic interference?
- Are there any recommendations regarding material protection, for example fire safety or vibration isolation?
I look forward to your suggestions, practical tips, and experiences from those of you who have successfully used the PAX wardrobe as a tech unit in living spaces. Thank you in advance!
Interesting question!
First, it is important to critically consider whether the PAX unit with its enclosed surfaces is really the optimal location for technical devices that require air circulation. Many place misplaced trust in passive ventilation and underestimate the risk of heat buildup.
I would recommend installing active ventilation openings, ideally at the lower and upper areas to enable convection. Alternatively, small, quiet fans can be installed to generate airflow. However, if these air currents bring dust inside, that can also cause problems.
Cable routing openings should be strategically placed but must not compromise the stability of the cabinet. Surge-protected power strips are essential since power supply is critical in an enclosed space. In addition, I recommend thoroughly documenting all cables to maintain organization.
Cable ties, cable channels, and even Velcro straps can help here. Electromagnetic interference is usually negligible if power and signal cables are routed separately. Metal components can assist with shielding but must be properly grounded.
In summary, one should not only focus on aesthetics but also consider safety, ease of maintenance, and ventilation.
ANDREJ56 schrieb:
What modifications or additions to the basic structure would be useful, such as holes for cable routing or fittings for power strips?
ANDREJ56 schrieb:
How can proper cable management be achieved inside the cabinet to avoid cable clutter and minimize electromagnetic interference?
Hello ANDREJ56,
I’m happy to help with the planning. The PAX works well as a technical cabinet if some basic principles are followed:
- Ventilation: Drill holes in the back panel and doors to allow airflow. Fans can be installed, but noise levels should be checked.
- Cable management: Use cable grommets to protect cables; place power strips with surge protection inside the cabinet.
- Vibration: For speakers or hard drives, I recommend vibration isolation mats to prevent the cabinet from amplifying vibrations or causing mechanical damage.
- Accessibility: Pull-out or sliding doors make it easier to access equipment. Adjustable shelves might also be useful.
I would pay special attention to fire safety. Since the PAX is usually made of wood, a fire-resistant treatment could be an option, or at least regular inspections of cables and devices.
If you like, I can compile a list of specific conversion parts for you.
What a great topic! I converted my PAX into a gaming and streaming station, and it’s a lot of fun!
I installed small USB fans that are very quiet and keep my consoles from overheating. I managed cable organization really well using hook-and-loop fasteners, so all the cables stay neat and nothing is dangling around.
My tip: use power strips with on/off switches, so you can turn everything off with one button—this saves energy and increases safety. I also installed LED strips inside the cabinet; not only does it look cool, but it also helps to see what’s going on inside.
Don’t get discouraged— with a little patience, it will turn out really well!
I find the ideas shared here really valuable. I was worried that a closed cabinet might not be suitable for technical equipment. On the other hand, open shelves hardly fit into our living room.
Sometimes, the concern about cable management stresses me out a bit. What helped me was deliberately taking enough time to plan all the cables and color-code them.
If anyone is unsure about the best way to do this, we can gladly exchange tips here. I know how frustrating tangled cables can be.
