ᐅ How can the Ikea Pax system be optimized for storing winter clothing?
Created on: 1 Jul 2022 09:37
Darrell61
Darrell61
1 Jul 2022 09:37
I would like to start a discussion on the topic: “How can the Ikea Pax system be optimally used and possibly improved for storing winter clothing?”
My goal is to find a practical solution that is both space-saving and organized. I am especially interested in how to store different types of clothing such as thick winter coats, sweaters, wool scarves, and shoes. Additionally, I am looking for tips on how to best store seasonal clothing when it is not in use, without causing damage or taking up too much space.
Since the Pax system is very flexible, it would be great to hear how you have set it up or which additions/DIY ideas you would recommend to achieve maximum functionality.
I look forward to your answers and suggestions!
sarlo
1 Jul 2022 11:26
Hello Darrell61,
I completely understand your question, as seasonal storage and organization can often be quite complex.
Regarding the Ikea Pax system, I recommend considering the following points:
- Use adjustable shelves to make the most of the storage space, for example, for folded sweaters or thin scarves.
- For thick winter coats, wardrobe rails positioned at a height that provides enough space are important, as the volume can quickly suffer otherwise.
- Add storage boxes or fabric bags to keep shoes or smaller accessories protected.
- One idea is to store seasonal clothing in vacuum bags and then stack them in the lower Pax compartments. This saves space and protects against dust.
- If possible, boxes with transparent fronts or labels can help maintain an overview.
An additional tip: besides just storing the clothes, remember to clean them before putting them away to prevent moths or odors.
I hope this helps!
Charles
2 Jul 2022 14:04
sarlo schrieb:
Use adjustable shelves to make the most of storage space, for example for folded sweaters or thin scarves.
I would like to add a bit more to this point: When using extra organizer elements in the Pax system, such as drawer inserts or dividers, you can customize the storage space even better. Especially for winter clothing, which varies in thickness and size, this helps prevent items from being crushed while keeping everything well organized.
Additionally, I recommend equipping the Pax wardrobe doors with internal hooks or small pockets. This way, hats, gloves, or scarves can be stored within easy reach and neatly.
I also consider air circulation an important aspect: Garments like down jackets should not be kept in airtight containers for too long, as this can affect the material properties. Vacuum storage bags are therefore better suited for pure wool or cotton sweaters than for more delicate fabrics.
It is also worth keeping sachets with textile disinfectants on hand to prevent moth infestations later.
Overall, I believe that a well-planned interior for the Pax system makes all the difference, ensuring winter clothing is not only neatly stored but also preserved for long-term use.
theota
3 Jul 2022 07:51
Darrell61 schrieb:
My goal is to find a practical solution that is both space-saving and well-organized.
I would like to offer a different perspective here: Does it always have to be as space-saving as possible? Especially for winter clothing, which is rarely used daily and often quite bulky, space is definitely more important than complete compression. Vacuum bags may seem like a clever idea at first, but over time they can damage the fabric structure, and the volume often quickly returns once you open them.
In my opinion, you should also consider the storage duration and the quality of the garments. Particularly high-quality down jackets or hand-knitted sweaters need to be handled carefully, stored so they can hang freely or be loosely folded. Ease of access and preserving quality should come before an obsession with optimization.
The Ikea Pax is certainly versatile, but the optimal solution strongly depends on what you prioritize: saving space versus preserving the clothing.
In conclusion: Those who focus too much on "maximum" use risk causing more damage to the material through improper storage than the space they save.
